3dof
Discussion in 'News' started by tmp, Mar 2, 2019.
  1. tmp
    tmp Member
    295Coins
    2DOF, 3DOF, Arduino, SimforceGT
    I do not know what problem I have that I have bad to have if someone can give me a hand I recognize the engines but with the game do not move and I get green and then when I put the game happens to me blue but do not move thanks in advance
    154,580Coins
    +11,190 / 57 / -2
    You will need to provide more information.
    Can you please post pictures of all of your settings. Does the rig hardware respond correctly with whatever code you are using with it?
  3. tmp
    tmp Member
    295Coins
    No sé qué problema tengo, qué mal tengo si alguien me puede dar una mano. Reconozco los motores, pero con el juego no me muevo y me pongo verde y luego, cuando juego, el juego me pasa a azul, pero no lo hago. muévete gracias de the code I have is smc3 0.70 Wiring-3-Motors.jpg
    154,580Coins
    +11,190 / 57 / -2
  5. tmp
    tmp Member
    295Coins
    the program connects me well and goes from green to blue but still I can not get the engines working with me, I'm thinking of buying simtools and having the plugins. but have if I'm using good code and good setup.
    It can be very weird, but everything goes with the game.
    a greeting
  6. tmp
    tmp Member
    295Coins
  7. tmp
    tmp Member
    295Coins
    good steps my photos have if you know the fault does not connect me I have the card is arduino one and pololu 5019 the motors works with the potentiometer but when I move them from simtools they do not move.
    Thank you
    154,580Coins
    +11,190 / 57 / -2
    Everything must work and the rig must respond correctly in SMC3 before bothering with SimTools.
    Just so you know you can't run the SMC3 utility and SimTools at the same time, it causes a port conflict.
    Your also need to have run at least one race in first person mode in LFS before it is patched for motion, as that generates some required files. If you did not do that then unpatch, run a race then close and repatch LFS.
    Your axis assignments in SimTools are also odd, normally roll and Sway would be opposite settings, this is what SimTools expects in terms of which was a rig is configured to move: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    You also need to be mindful of the total allocation % total in Axis Assignments: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Once you do get te rig moving in SimTools this is how your go about creating and refining a motion profile, initially doing one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  9. tmp
    tmp Member
    295Coins
    [QUOTE = "noorbeast, post: 174576, miembro: 10786"] Todo debe funcionar y la plataforma debe responder correctamente en SMC3 antes de molestarse con SimTools.
    Solo para que sepa que no puede ejecutar la utilidad SMC3 y SimTools al mismo tiempo, se genera un conflicto de puertos.
    También debe haber ejecutado al menos una carrera en modo de primera persona en LFS antes de parchearse para el movimiento, ya que genera algunos archivos necesarios. Si no lo hiciste, entonces desempaquetar, corre una carrera, luego cierra y vuelve a emparejar LFS.
    Sus asignaciones de ejes en SimTools también son impares, normalmente, el balanceo y Sway serían ajustes opuestos, esto es lo que SimTools espera en términos de los cuales se configuró una plataforma para moverse: https://www.xsimulator.net/community/faq/which -de-camino-a-conjunto-simtool-ejes-movimientos.230 /
    También debe tener en cuenta el porcentaje total de asignación en Asignaciones de ejes: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Una vez que logre que el equipo se mueva en SimTools, así es como puede crear y refinar un perfil de movimiento, haciendo inicialmente un eje a la vez: https://www.xsimulator.net/community/faq/steps-to-create- a-motion-profile.228 / [/ QUOTE]
    thank you very much fellow for your rapides and your help then I try it and I tell you
  10. tmp
    tmp Member
    295Coins
  11. tmp
    tmp Member
    295Coins
    comrades and moves that happy to give me thank you very much and thanks to this forum a pleasure. I can not download plugins for asseto and dirt rally that I have to buy or as I do.
  12. noorbeast
    154,580Coins
    +11,190 / 57 / -2
    You need a licensed version of SimTools to use plugins.
    You can your forum activity coins or real money to buy access to plugins: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    SimTools (motion software) licensing and Xsimulator.net (community and community developed plugins) are two separate entities, see here to find out more about the relationship between the two: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
  13. tmp
    tmp Member
    295Coins
  14. tmp
    tmp Member
    295Coins
    you know if the pololu 5019 plate can be fed with a 24v source or can only be fed with 12v thanks
  15. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
