Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    50,838Coins
  2. yobuddy
    50,838Coins
    yobuddy updated Motion Simulation Software SimTools with a new update entry:
    SimTools v2.4
    Read the rest of this update entry...
  3. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,275Coins
    @yobuddy
    Wow, that's an impressive list of features update!!!
    Your hard work is much appreciated, thank you so much!
    Would you advise a complete un-installation of the previous version, or since this is a sequential v2.x one, would it be fine to just install over it?
    Just curious if we'll need to backup our info/axis/motion profiles?
    Cheers, and thanks again!
  4. yobuddy
    50,838Coins
  5. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Great work ! A big "thank you" to yobuddy :)
  6. evolaco
    evolaco Member
    Spain
    694Coins
    What is the feature of the new loss traction filter?
  7. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    Same asking at vibe,
    thanks for this update. what you suggest to install it, and to conserve the current settings of the b53 release ?
  8. yobuddy
    50,838Coins
    Install over the top of the old version and you should be good to go!
  9. yobuddy
    50,838Coins
    Its basically just like the washout filter except only forces moving away from center affect the output.
    (rather than away and toward center.)
    This lets the back end spin out and will let it slowly return to center as needed.
  10. Mechromancer
    434Coins
    Maybe it's just my imagination, but 2.4 seems a little smoother.
    Awesome work!
  11. yobuddy
    50,838Coins
    :thumbs
    It's not your imagination, its a ton of work lol.
    Take care buddy!
    • Winner Winner x 3
  12. Mechromancer
    434Coins
    Yeah, my bad. A ton of work for sure! :)
  13. yobuddy
    50,838Coins
    Honestly, I'm just glad you can tell buddy! lol :thumbs
  14. Corporatezombie
    Corporatezombie Member SimAxe Beta Tester Gold Contributor
    Leicestershire
    148Coins
    3DOF, SCN5
    It seems that Simtools installs to C: drive no-matter if you tell it to install elsewhere. Just sayin... :)
    Sorry I didn't mean this to come across as sarcastic. Just that it wasnt a big deal. I mean even Nvidia dont let you install to a different drive.
  15. yobuddy
    50,838Coins
    I just installed it on my games (E) drive no problem.
    You simply select the path you want when you install it.
    Take care,
  16. Kranky Pantz
    Canada, Eh!
    1,275Coins
    Follow @yobuddy's steps outlined above to select the drive + path of your choice.
    SimTools is sitting happily on my D: drive within my other directory of Sim related apps & programs.
    Just sayin'... ;)
  17. Corporatezombie
    Leicestershire
    148Coins
    3DOF, SCN5
    How strange that I browsed to the drive and then watched as it installed to C instead. I'll uninstall it and try again.
  18. Hocky
    Hocky Member
    127Coins
    I updated Simtools from 2.3.1 to 2.4 and got some strange behaviour.
    Running 3DOF (d-box style) with traction loss, Thanos AMC-MDBOX with PT-Actuators and updated the interface plugin and firmware to the latest version.
    I changed the interface from AMC 128... to just AMC and selected MDBOX as in the instructions I got.
    The strange thing is that with the exact the same settings I got alot less motion.
    The main gain was before 75 and now I need to max it out to 100 to get close to the same motion?!?
    I feel that the traction loss still moves as it should but not the "legs"?!?
    Is anyone else having the same problem?
    Thanks!
    151,718Coins
    +11,045 / 56 / -2
    I am guessing you need to tweak your motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  20. Hocky
    Hocky Member
    127Coins
    Change the motion profile so a 2.3.1 setting of main level of 75 need almost 100 on 2.4 is ok?
    I really dont know how to change the motion profile (to get larger movements) without adding alot to the DOFs and then going way over 100% in total. It was working fine before but I feel something strange is going on.
    Have done some work in the tuning center to but it will not wake up.
    Could it be something when changning interfaces?
    I could read something about AMC users needed to unselect the old before updating. I did that but could something be messed up there?
    I may unistall and do a fresh install of Simtools and AMC firmware and see if it works better.
