My first 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by FLORIN ROMANIA, Jan 23, 2023.
  1. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    810Coins
    And how could I check this?
  2. FLORIN ROMANIA
    România
    810Coins
    Is it possible because I have simtools 2 and simtools 3 beta downloaded, do I need to delete one of the versions?
    153,986Coins
    +11,162 / 57 / -2
    I have not done it, but am guessing if you have a female usb cable lying around you don't mind sacrificing you could cut that, so you can have easy access to the wires, plug the wheel in to that and test for interference with a multi-meter.
    No, both can be installed on the same computer, that is not the issue.
  4. FLORIN ROMANIA
    România
    810Coins
    But on the other pc I only had simtools 2 installed and it worked perfectly, just with the keyboard, no steering wheel, but I could play LFS without any problem
  5. FLORIN ROMANIA
    România
    810Coins
    I will try to change the local English and then come back with news, thanks for the guidance
  6. FLORIN ROMANIA
    România
    810Coins
    Hello, you were right, the pedals on the steering wheel have a small problem, the cable is not properly insulated, I solved the problem, thanks for your help
  7. FLORIN ROMANIA
    România
    810Coins
    Hello. where can i find instructions for simtools v3?
    153,986Coins
    +11,162 / 57 / -2
  9. FLORIN ROMANIA
    România
    810Coins
    I have a problem, when I start simtools my sim rig sits straight, when I open axis testing it leans to one side, then when I play f1 its shaking, no game telemetry
    153,986Coins
    +11,162 / 57 / -2
  11. FLORIN ROMANIA
    România
    810Coins
  12. FLORIN ROMANIA
    România
    810Coins
  13. FLORIN ROMANIA
    România
    810Coins
  14. FLORIN ROMANIA
    România
    810Coins
    Hello. This is the telemetry I have, it's ok or i have to change something?
  15. FLORIN ROMANIA
    România
    810Coins
    Hello, is it necessary to reinstall simtools with firewall and antivirus disabled?
  16. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    Sometimes, SimTools by necessity accesses game data and some AV get overly aggressive.
  17. FLORIN ROMANIA
    România
    810Coins
    Hello. Is there any relation between khz in telemetry and khz in smc3 utility?
  18. FLORIN ROMANIA
    România
    810Coins
    Hello. What are these settings for?
    153,986Coins
    +11,162 / 57 / -2
    153,986Coins
    +11,162 / 57 / -2
    A SimTools v3 manual has yet to be written, as it is in Beta testing and subject to change, but fundamentally the Tuning Center values serve the same purpose as in V2, p.77 onwards: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Also see the motion profile tuning tips in the FAQs: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Basically you capture base settings for the Tuning Center: http://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/
    From there manually tweak the settings. Raising the Tuning Center values will soften the motion over a greater axis movement, lowering the value will do the reverse. See here for an expanded explanation: https://www.xsimulator.net/community/threads/graphic-simtools-parameter-adjustment.9054/#post-113925
