3dof motor 3 only going one direction
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Nikkatai, Sep 10, 2022.
  1. Nikkatai
    Nikkatai New Member Gold Contributor
    97Coins
    So I’ve got my rig back up and running but motor 3 only goes in one direction! I’ve almost tried everything, I’ve swapped out the ibt2 thinking it may of been a driver problem, tested the ibt2 on different pwm input on Arduino and same result, and I’ve tested the motor in position of motor 2 and works perfectly, I’m running 3x 33a led power supplies relay per motor to estop, any ideas? All I can think of is maybe the pins on the jumpers are not contacting properly.
    152,165Coins
    +11,066 / 56 / -2
    Are you using wiper motors?
  3. Nikkatai
    97Coins
    Nah motion dynamics 20nm 200w, it’s pretty strange I’m going to recheck the wiring do a few more test, the other 2 are perfect. Unless I’ve got faulty batch of ibt’s? I’ll check that theory as well.
    152,165Coins
    +11,066 / 56 / -2
    You could try a different Arduino or possibly baud rate.
  5. Nikkatai
    97Coins
    Yeah I might have to, just seems weird that when I swap the ibt from motor 2 to the 3rd input on the Arduino it works fine… just checking over this wiring once more if no go I’ll shoot down and grab one! And changing the baud rate? How do I do that? I’d have to change the code to get it working in smc3 ay?Thanks for your help!
    152,165Coins
    +11,066 / 56 / -2
  7. Mauro Nicolas Mugnolo
    Mauro Nicolas Mugnolo New Member
    79Coins
    DC motor
    My friend, the same problem happens to me, my motor only activates the force in one direction, what could it be? I do use a windshield wiper motor.
    152,165Coins
    +11,066 / 56 / -2
  9. Mauro Nicolas Mugnolo
    79Coins
    DC motor
    I already did the isolation now I have 3 cables but I don't know how to connect them to the bt7960
    PD:
    It strikes me that it only hard loock in one direction and not in the other, could it be that my BTS7960 is damaged?
    152,165Coins
    +11,066 / 56 / -2
    3 wires is likely hi and low speed for wipers, you need to work out which wire is which.
    Do the motors rotate in both direction by reversing the polarity if directly wired to a battery or PSU, so taking the controller out of the equation for a moment to ensure the motors are working as expected?
  11. Mauro Nicolas Mugnolo
    79Coins
    DC motor
    I am testing the motor with a computer source but my problem is that I do not know how to connect the cables to the bts7960 since I have everything configured correctly I am using EMC UTILITY I use this electrical diagram
  12. Nikkatai
    97Coins
    Mine was a loose pin I hard wired everything all is good now!
  13. Design89
    Design89 Member
    Netherlands
    214Coins
    That's a different setup then most people are using here. It could probably work if your code has the same pins.
    Did you have a look here? https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
  14. Design89
    Design89 Member
    Netherlands
    214Coins
    Great! I've the same problem, but I cannot find loose wires. Got some strange reading on the IBT output aswell.. This week I will get new IBT's to test from start again.
    Which wiring diagram did you use?
  15. Nikkatai
    97Coins
    This one here
  16. Nikkatai
    97Coins
    Just make sure you use smc3 to ensure the motor is following the green line( potentiometer) if not, reverse the motor wiring or pot wiring, a lot of info in the forums on how to do that.
  17. Design89
    Design89 Member
    Netherlands
    214Coins
    Thanks. I use the same wiring diagram.
    If I reverse the pot wiring, it does nothing. Green line won't move than.
    Reverse the motor wiring, only changes the direction of the motor and has the same problem.
    I did some testing with a volt meter
    https://www.xsimulator.net/community/threads/3-dof-faulty-ibt-one-direction.17572/
