Ville Pesonen
War Thunder Plugin 2.3.1.1
SimTools V2 plugin for War Thunder
  1. ERGUN OZYURT
    ERGUN OZYURT erguno
    Turkey
    - 246Coins
    2DOF, 3DOF
    I am using Licensed version.
    153,818Coins
    +11,150 / 57 / -2
    In that case is SimTools activated?
    Perhaps @yobuddy has some other ideas.
  3. yobuddy
    51,531Coins
    @ERGUN OZYURT
    Will you post a screen shot of the game manger drop down list of games?
    Thanks man,
  4. ERGUN OZYURT
    ERGUN OZYURT erguno
    Turkey
    - 246Coins
    2DOF, 3DOF
    Thanks for help.
    153,818Coins
    +11,150 / 57 / -2
    Try temporarily turning off programs that could interfere with the patching, like anti-virus and firewall, un-patch and then re-patch WT.
  6. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    In my case I have a kill switch next to me to switch off power supply to the motors. It works well with any games.
  7. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    one of those
    153,818Coins
    +11,150 / 57 / -2
  9. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    google traductor: english
    I AM A NOVICE IN THIS WE ARE SORRY ... Hello friends, I have a problem with the true no of war and I do not know if it is normal, but as you will see in the telemetry (tuning center) it does not provide the correct information and the simulator does not fire anywhere. Someone with 2dof can send a screenshot of their tasks. PS: I LOVE THIS CREATOR PLUIG thanks !!!
  10. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    traductor google
    Hello friends, here is a video with the error I have with War Thunder. I make the comparison with a bomber plane and a fighter plane.
    I have the latest version of WAR THUNDER.
    See if they can help me, as you will see in the tuning center roll and launch with an airplane (fighter: bf 109 f_1) they do not have telemetry in (roll, launch) and if I change to an airplane like the (bomber: Do 217 j -1 ) You will see that roll, pitch shows the numbers it responds to. And the simulator behaves as it should only with that plane (Do 217 j-1)
    153,818Coins
    +11,150 / 57 / -2
    Try using Extra 1 and 2 instead of traditional roll and pitch:
    Extra1: Roll speed in degrees / second
    Extra2: "Pitch speed" = Position of Elevator
    It could be the known language bug affecting traditional roll and pitch, but you would need to test it to know: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  12. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    GREAT AT THE END IT WORKED THANK YOU VERY MUCH NOORBEAST
  13. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    When selecting axis, for example roll, pitch, heave, yaw, saway, surge, extra1, extra2, extra3. this in game engine you must respect its position for example (DOF1) (DOF2) (DOF3) (DOF 4) (DOF5) (DOF 6), MY DOUBT IS IN WHAT POSITION WOULD I HAVE TO HAVE THE VIBRATION OF THE FLOOR? although I
    don't know if this pluig works
    translated with google
    153,818Coins
    +11,150 / 57 / -2
    I am not sure what you mean, are you talking about heave when you say vibration of the floor?
    What matters are how each axis is configured not what order they are, this is what SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    It would probably help if you post pictures of all of your settings.
  15. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    FOR EXAMPLE I WANT TO FEEL THE VIBRATION OF THE ROAD (
    highway)
  16. noorbeast
    153,818Coins
    +11,150 / 57 / -2
    Sounds like you mean the runway vibrations for takeoff and landing.
    It is a bit of a trade off between on the ground and in the air settings for both heave and pitch. Best to tune and test both individually, with other axis turned off, to find the best compromise for your rig, see the tuning tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Personally I also use transducers, and on my dad's rig rumble motors, for finer vibrations, as I have a heave axis and want that satisfying thump when touching down.
  17. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    If I meant the track I'm sorry hehe. I have verified that to feel the vibration of the track I have to raise the intensity to 100% and that will cause injuries to my body. Is there any way to feel the track with a softer intensity?
    Thank you!!
  18. noorbeast
    153,818Coins
    +11,150 / 57 / -2
    Follow the tips in the link provided to refine the motion profile, you don't need to wind up Axis Assignments to 100%, rather you need to use smaller Tuning Center values (can even be smaller than 1 for things like heave in some race games), which create very fast responses over a small axis range for surface vibrations.
    You can also grab the SimTools manual here: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
  19. Surferjo86
    Surferjo86 New Member
    Sheffield
    43Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF, 6DOF
    Starting to build my 2DOF simulator this month, Really only for war thunder VR.
    I'm wanting to build a force feedback stick too. Is there a speed output for this plug in?
    I don't want anything too complicated for the feedback. Just want the centring to become more pronounced with speed. Would this be possible with the plug in?
    Cheers Joe
    153,818Coins
    +11,150 / 57 / -2
    The plugin outputs are listed on its Download page: https://www.xsimulator.net/community/marketplace/war-thunder-plugin.176/
    The plugin is not created for force feedback.
    You could check out something like the Microsoft sidewinder force feedback 2 joystick, and some of the mods people have done to it to try and get it to work with WT: https://forum.warthunder.com/index.php?/topic/355994-sidewinder-force-feedback-2/
