Ville Pesonen
War Thunder Plugin 2.3.1.1
SimTools V2 plugin for War Thunder
  1. noorbeast
    153,932Coins
    +11,157 / 57 / -2
  2. Youngsoo Cho
    Youngsoo Cho VR Sim Racing Gamer
    Business Man
    Korea
    467Coins
    153,932Coins
    +11,157 / 57 / -2
    Normally the DIR setting for sway would be the opposite of roll.
    Start by disabling allocations and do one at a time, starting with roll, then when it is correct turn it off and do pitch and so on: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    For now do away with Startup and Shutdown settings in the Interface Settings.
    You only have 2 axis defined in the Interface settings but there are axis allocations for 3, not sure what your rig is.
  4. Youngsoo Cho
    Business Man
    Korea
    467Coins
    I use Dof Reality V3 which is 3dof. :(
  5. gxwaw101
    gxwaw101 New Member
    77Coins
    2DOF, 3DOF
    Hi, I am using 2dof and im want to play War Thunder. Problem is that 2dof makes strange movements in logging like 1 second move, same in menus, so the game is communicating with simtools. But in a flight simulator isn't moving whathovewer, do you know where problem is?
    153,932Coins
    +11,157 / 57 / -2
    You will need to give far more detail, like posting pictures of all of your settings.
    Have you gone through each of the steps to refine the motion profile, one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    And does SimTools behave correctly in Output Testing, this is what SimTools expects in terms of axis configuration: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  7. Jaysonchou111
    Jaysonchou111 New Member
    188Coins
    Wt has a plug-in? Looks like I made it
  8. Jaysonchou111
    188Coins
    realy nice ,drive tank can use this?
    153,932Coins
    +11,157 / 57 / -2
  10. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    It works perfect, thanks for that, is there any way I can feel when I shoot?
    153,932Coins
    +11,157 / 57 / -2
  12. polybasss
    Burgos Spain
    155Coins
  13. polybasss
    Burgos Spain
    155Coins
    I have followed the tuning center adjustment steps, I have modified the values of both surge and heave but I do not notice any change and of course I have saved after each change
    153,932Coins
    +11,157 / 57 / -2
    You need to properly tune your Surge vales to feel the kick of guns, particularly cannons.
  15. polybasss
    Burgos Spain
    155Coins
    @noorbeast ,I got it!!! the problem was that I did not have the added arises in the axis, I did not know that in a 2dof you can add more forces dof than 2, I thought that was done by adding axis
  16. Ville Pesonen
    Ville Pesonen Active Member
    867Coins
    Ville Pesonen updated War Thunder Plugin with a new update entry:
    Added support for GameVibe and GameDash
    Read the rest of this update entry...
    153,932Coins
    +11,157 / 57 / -2
    Thanks for all your work in adding Game Vibe and Game Dash support @Ville Pesonen, it adds so much to the experience!
  18. Youngsoo Cho
    Business Man
    Korea
    467Coins
    Thank you!
    153,932Coins
    +11,157 / 57 / -2
    Please post pictures of all off your setting.
    My guess is that your motion profile needs refining, this is what a crash should look like:
  20. Youngsoo Cho
    Business Man
    Korea
    467Coins
    Your rig's movement looks super normal. my rig moves like a really crazy horse.
    by the way I found that sway value is abnormal. it is way too big. please check this.
    DOF Reality V3 I use
