DIY Playseat update with 2/3 DOF Arduino, MonsterMotor
Discussion in 'DIY Motion Simulator Projects' started by DirtDro, Jun 29, 2017.
  1. noorbeast
    152,373Coins
    +11,076 / 56 / -2
    Do you have the motor and electronics hooked up yet?
  2. DirtDro
    DirtDro X-plane Rheinstetten
    213Coins
    After a few small parts were missing, I now wired the electronics and the engine. On the first try, the power was set too high and a monster motor burned out. With the right attitude, as described by smc3, everything worked and the engine runs.
    Now I only need the levers on the motors, the holders for the pots and the software simtooos with license.
    It was a bit of time for flying with x-plane lost.
    Greeting Dirk
  3. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Gut, dass du die Ebay Motoren nicht gekauft hast. Die habe ich nämlich und die bekommen sehr schnell heftig Spiel.
  4. DirtDro
    213Coins
    This weekend I want to finish my lever. I bought two clamping rings and flat steel. I hope that the seat then moves as expected.
  5. DirtDro
    213Coins
    Today I get my simtools license.
  6. DirtDro
    213Coins
    Hello
    Since I did the theory training in the last weeks for the real UL (LSA) pilot licenc, I did not have much time for the simulator.
    The levers are almost done now. I welded the holders for the potentiometers. Only the push rods made of M8 threaded rods are too soft.
    Now the x-plane software is still missing. Where can I get the x-plane plug in software?
    152,373Coins
    +11,076 / 56 / -2
  8. DirtDro
    213Coins
    Both engines are running now. After a long test, I found a defective monster motor driver.
    The cables are still laid clean.
    The push rod from engine to frame in M8 is too soft.
    Simtools only runs in DEMO mode?
    Where can I enter my license code?
    Is the X-plane plugin also available for free?
    greeting
    152,373Coins
    +11,076 / 56 / -2
    See here regarding how to use your SimTools 2.0 discount code to get your free copy: https://www.xsimulator.net/communit...-question-and-answer.8175/page-25#post-122220
    How to Register SimTools 2.0: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
    You can use forum activity coins or real money to gain access to all plugins: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
  10. DirtDro
    213Coins
    Thank You
    my simtool licens are now aktiv
    first the poti has the wrong direction, now with smc3 the motors work perfect.
    with PWMmax 110 i had 14 A
    But with simtools 2.2 the motors not move
    152,373Coins
    +11,076 / 56 / -2
    Are your SimTools Interface settings like this;
    [A<Axis1a>][B<Axis2a>]
    Set for 10bit binary output
  12. DirtDro
    213Coins
    I already had these attitudes.
    After changing the language to English (US) simtools works.
    Is the update to 225 the language bug (simtools bug) fixed?
    Now the plugins for x-plane and I can go.
  13. DirtDro
    213Coins
    X-plane Works with simtools now
    I Had to change the Direction of pitch
    The Motors move Not smooth
  14. Bastiuscha
    750Coins
    With hall sensors, your motors will be smoother and more position accurate. In case you have normal pots...
    152,373Coins
    +11,076 / 56 / -2
  16. Milt
    Milt Member
    USA
    32Coins
    About to order my rod ends for a project similar to yours. Are you saying there is too much flex in the M8 rod? Think an M10 rod would do?
    Thanks.
    152,373Coins
    +11,076 / 56 / -2
    It is easy to make a suitable strong rod using steel tube with the appropriately sized nut welded either end.
  18. DirtDro
    213Coins
    noorbeast was faster.
    I will replace or reinforce my threaded rods against steel pipes.
    The error with the rough run, I have also found.
    I connected the potentiometers directly to the motor shaft. It caused vibration. Had the same with hall sensors.
  19. DirtDro
    213Coins
    the hard engine did not come through the potentiometer but from a high PWM min. Value. I have 10 now. Behold, the engines are running softer.
    I have shaft couplings mounted on the pots.
    Settings for x-plane:
    When I control slowly with x-plane roll and pitch and the plane rises slightly or flies a flat turn, the seat does not respond.
    During fast movements of the aircraft, the seat also reacts. After a few turns, does the seat and plane have a different inclination in the game?
    How do I have to set the values for extra 1-3 in the tuning center (xsim V2.2)?
    thank you for your help
    152,373Coins
    +11,076 / 56 / -2
