simple 2 dof wiper sim
Discussion in 'DIY Motion Simulator Projects' started by Arunas, Apr 1, 2017.
  1. Arunas
    Arunas Member
    Lithuania
    2Coins
    Hello all. Im a new noob with bad english who started to build 2 dof simulator. Now what i have:Arduino Uno R3, 2 pcs wiper motors ( got it olmost free ), 2 pcs pots 10K, Monster moto motor driver, 12V 30 A power supply.
  2. Arunas
    Arunas Member
    Lithuania
    2Coins
    Wiper motor ground isolation is ok. Followed the advice of bsft.
  3. Arunas
    Arunas Member
    Lithuania
    2Coins
    Used MonsterMoto Shield Example Sketchdate: 5/24/11code by: Jim Lindblomhardware by: Nate Bernstein SparkFun Electronics, to test my connections. Both wiper turns from one side to another. Tested without pots.
  4. Arunas
    Arunas Member
    Lithuania
    2Coins
    Used this example to connect everything.
    Now what I have
  5. Arunas
    Arunas Member
    Lithuania
    2Coins
    Cant upload image.
  6. Arunas
    Arunas Member
    Lithuania
    2Coins
    My future plan to use 2 dof in DCS.
    Now im going to:
    1. Install Simtools and Life for speed to test everything is working with pots.
    2. If test success I will start to build seat.
    Please post somebody is it right plan or I need somethingto install more ? Thank for everybody for adwise. Will post my results of my project.
    152,694Coins
    +11,090 / 56 / -2
  8. Arunas
    Arunas Member
    Lithuania
    2Coins
    Thank you noorbeast for your replay. I will try SMC 3 firs. But first I need cooling fan on my motor driver modul because it is very hot and read more FAQ.
    152,694Coins
    +11,090 / 56 / -2
  10. Arunas
    Arunas Member
    Lithuania
    2Coins
    Some parts of my future moving seat.
  11. Arunas
    Arunas Member
    Lithuania
    2Coins
    I placed cooling fan on my motor driver modul. Now the temperature is ok. Worked about an hour without heating.
  12. Arunas
    Arunas Member
    Lithuania
    2Coins
  13. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Not at all. But depending on the model you will have to isolate it from mass.
  14. Titobial
    Titobial Member
    Zaragoza
    159Coins
    It goes to taste. It will depend on the power you want and have in power supply and amps. I use 24v with 700w source and 49 amps.
  15. Arunas
    Arunas Member
    Lithuania
    2Coins
  16. Titobial
    Titobial Member
    Zaragoza
    159Coins
  17. Arunas
    Arunas Member
    Lithuania
    2Coins
    I am sorry, it is not mine idea. It is the advice of @bsft
  18. Titobial
    Titobial Member
    Zaragoza
    159Coins
    Already. I see that you are not the author of the tutorial. But when you put the link, I only meant that it is a good contribution. Regards!
  19. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hi, for the choice of engines (12v or 24v), I suggest 24v to lower the currents in play, but much depends on the results of the set.
    I have 24v motors, but at the end I had to power them with 12v to decrease the speed it was approaching and make the simulator too nervous.... ;)
  20. Arunas
    Arunas Member
    Lithuania
    2Coins
