Frex 2DOF - SCN5 conversion
Discussion in 'Commercial Simulators and Peripherie' started by RobertH, Nov 23, 2016.
  1. RobertH
    RobertH Member Gold Contributor
    The Netherlands
    1Coins
    2DOF, SCN5
    I'm in the process to make my Frex 2 DOF 2 SCN5 motion seat to work with XSimulator:
  2. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
  3. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
  4. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    I have added sway and surge motion to axes 1 and 2
  5. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    If anyone have any suggestions, please let me know.
    153,914Coins
    +11,154 / 57 / -2
    You need to do an Axis Assignment for Automobilista, the picture you posted is the Default, which works for testing but not for game. Each game has to have its own Axis Assignment.
    Have you patched the game for motion and if so to what install path?
    It would normally be Steam_Install_Path\Steam\steamapps\common\Automobilista\Plugins
    Once you do get it moving then you need to develop and tweak the motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  7. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    I have Assigned the axis for Automobilista and patched the game for motion.
    I've used the following dir to patch the game: D:\SteamLibrary\steamapps\common\Automobilista
    Its working now :)
    Thanks!
  8. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    Installed and patched Raceroom experience but i get no motion.
    I did the same with rFactor 2 and that game works fine.
    Are there any know problems with RRE?
    153,914Coins
    +11,154 / 57 / -2
    Yes the latest RRE game update broke the plugin: https://www.xsimulator.net/community/threads/raceroom-racing-experience-plugin.4782/#post-118051
    See my comments here regarding why it is not likely worth fixing the 1.3 RRE plugin this close to the release of SimTools 2.0: https://www.xsimulator.net/communit...ing-experience-plugin.4782/page-2#post-118300
    There is a possible temporary work around suggested by @Erwan960 here: https://www.xsimulator.net/communit...ing-experience-plugin.4782/page-2#post-118626
  10. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    Thanks for letting me know.
    Can is start tweaking the motion profile or is it better to wait for SimTools 2.0
    And are there any 2DOF SCN5 profiles i can use as starting point?
    153,914Coins
    +11,154 / 57 / -2
    You should definitely tweak the motion profiles.
    First to gain experience, as it gets quicker and easier with practice.
    And second because a dialed in profile tweaked specifically to suit your simulator and personal preferences is chalk and cheese in terms of far better motion.
    There are presets and you are welcome to go through them, but personally I consider it far better to dial in motion to suit your own simulator: https://www.xsimulator.net/community/categories/share-your-simtools-presets.150/
  12. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    I wonder.. would it be possible to disable certain motions, like Extra1 = Traction Loss (for example)?
  13. obobo
    obobo Active Member
    1,323Coins
    yes its possible
  14. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
  15. obobo
    obobo Active Member
    1,323Coins
    modife the preset, and remove the effect you don't want
