My 2DOF Sim project
Discussion in 'DIY Motion Simulator Projects' started by Mo165, Nov 11, 2015.
  1. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    Do you mean that nothing happens if you turn on the Output Testing in SimTools and move the sliders, but the motors do respond using the JRK config utility?
    If so then you have a configuration problem and need to post pictures of all your settings.
  2. Historiker
    9,205Coins
    I agree, I merged the threads so people can better help this member.
  3. Mo165
    Mo165 Member
    Austria
    103Coins
    Yes i will post them ;)
  4. Mo165
    Mo165 Member
    Austria
    103Coins
    So here are my pics
  5. Mo165
    Mo165 Member
    Austria
    103Coins
    My Settings what could be wrong?
      190.6 KB
      701
      182.4 KB
      716
      194.4 KB
      709
      196.9 KB
      685
  6. Mo165
    Mo165 Member
    Austria
    103Coins
    i hope you can help me
  7. Nick Moxley
    Have you confirmed your COM port #'s in the device manager ?
  8. Mo165
    Mo165 Member
    Austria
    103Coins
    I think i confirmed it, cause the pololu settings work
  9. Nick Moxley
    Simtools requires the proper ports to be selected manually, The utility does not.
  10. Mo165
    Mo165 Member
    Austria
    103Coins
    ok thanks i´ll take a look
  11. Mo165
    Mo165 Member
    Austria
    103Coins
    I changeed the numbers to COM6 and COM4 but how can i confirm them or whats actually ment?
  12. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    Go to control panel / Device Manager and check the com of your Arduino.
  13. Mo165
    Mo165 Member
    Austria
    103Coins
    I´ve checked the COM of my JRK all fine.
    Is it maybe a problem, that Simtools is running in the tray?
    153,788Coins
    +11,150 / 57 / -2
    SimTools is meant to run in the Tray.
    I have asked before but can you please confirm that you have default profile axis allocations and if the motors respond when you turn on Output Testing in SimTools and move the sliders.
    If that does not work please post pictures of all your JRK settings.
  15. Mo165
    Mo165 Member
    Austria
    103Coins
    I have Default Profile axis and even with them nothing work.
  16. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    Here are the basic JRK setup instructions by @eaorobbie: https://www.xsimulator.net/community/threads/playseat-to-2-dofseat.5401/page-2#post-56352
    On the Input tab of the JRK utility you need to uncheck Enable CRC, check Never sleep and apply those settings to device. Check Reset integral on the PID tab and apply. You can refine the settings further, particularly the PIDs: https://www.xsimulator.net/community/faq/practical-examples-video-tutorial-to-jrk-pid-tuning.225/
    You are allocating over 100% total to the Axis Assignments in SimTools, with way too much given for just 2 assignments: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    It takes time but once you have SimTools talking to the JRKs and everything works as expected in Output Testing you then need toi develop a motion profile, here is how you go about it: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  17. Mo165
    Mo165 Member
    Austria
    103Coins
  18. Nick Moxley
    How about you explain what you were doing wrong, that way if some one else new reads this, They might understand also.
  19. Mo165
    Mo165 Member
    Austria
    103Coins
    Yes of Course.
    First i didn´t know what to do, cause i have never done a Project like this.
    Next failure was that i didn´t look for explainations.
    After that i found something in the community but it still didn´t worked.
    So i asked @noorbeast who helped me a lot with something i haven´t checked like enable CRC.
  20. Mo165
    Mo165 Member
    Austria
    103Coins
    The Motor stops and wants to start again but without pulling the rig up it doesn´t work anymore.
