Question starting simtools interface type with wiper motors.
Discussion in 'DIY Motion Simulator Projects' started by Tags..(VR), Aug 12, 2018.
Tags:
  1. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    looking for a setup guide but no results. what would a wiper motor be listed under interface type in sim tools?
    only using one pc so dont think serial port would be the right match?
    154,580Coins
    +11,190 / 57 / -2
    How you set up the SimTools interface depends on the code and hardware you use to control the motors: https://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    I would suggest you try the SMC3 code, as it has a handy graphical app for configuring settings: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    Be aware that in most cases wiper motors need ground isolation: https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
  3. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Thank you for te fast responee but im already through this. im trying to create the interface with smc3 and sim tools in the interface selection.
  4. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    my question is what is the wiper motor listed as in the interface?
    154,580Coins
    +11,190 / 57 / -2
    In that case follow the SMC3 instructions, set the Output Type to serial with the following, delete [C<Axis3a>] if using 2DOF:
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    Set for 10bit binary output
    Baud rate 500000 , N , 8 , 1 (10ms delay)
