Question Kangaroo X2 vs. Arduino
Discussion in 'SimTools compatible interfaces' started by My.stAr, May 10, 2019.
  1. My.stAr
    My.stAr Active Member
    Engineer
    1,065Coins
    DC motor
    Can someone help me with the question:
    What is "better", Arduino with e.g. SMC3 or a kangaroo board?
    What are the advantages and disadvantages of the boards?
    I build my simulator with Arduino and smc3-sps. It was fine for me. But since I'm rebuilding my rig and have some kangaroo boards I'm asking myself if it would be better to use them?!?
    I would be happy to get some answershug:
    My.stAr
  2. yobuddy
    51,703Coins
    Are they the X2's buddy?
    I think the originals had a few bugs and were only around for a short time.
  3. My.stAr
    Engineer
    1,065Coins
    DC motor
    Yes, I have the X2.
  4. yobuddy
    51,703Coins
    From the limited feedback i have received on them, they are pretty cool man!
    Lots of auto setup stuff.
    would be cool so them compared for sure!
    Take care,
  5. My.stAr
    Engineer
    1,065Coins
    DC motor
    @BlazinH, since you wrote the smc3-sps and also lots of stuff about the kangaroos, I think you could answer this question?
    What are the main (dis)advatages of the kangaroo x2 and the Arduino with your Code?
  6. BlazinH
    16,701Coins
    Kangaroo:
    Pros - Works with encoders, self tuning
    Cons - Doesn't work good with pots, self tuning, unfamiliar tuning perimeters if manual adjustment necessary
    Arduino SMC3:
    Pros - Works with pots and hall sensors, familiar tuning perimeters (PID) to manually adjust
    Cons - Doesn't work with encoders on its own, 10 bit max analog sensor resolution
    There is only one Kangaroo version; the x2 stands for two motor control. Some report having issues with its self tuning feature though and manual adjustment is difficult so it can be either a pro or con depending on your own experience.
    • Informative Informative x 3
  7. My.stAr
    Engineer
    1,065Coins
    DC motor
    Thanks @BlazinH :thumbs
    Since I'd like to use encoders I'll give the kangaroos a try.
    Where could manual adjustments be neccesary?
  8. BlazinH
    16,701Coins
    Here's one.
    "The second problem was with control tuning. I was using Kangaroo x2's as PID controllers and for some reason they just refused to properly auto-tune. The tuning process completed without issues, but then bad ocscilations occured at some parts of the lever travel. I tried setting the coefficients manually, which helped a little, but could not fully solve the problem. I spent couple of weeks trying to fix that -- without success. Probably, I would have eventually found the cause of the problem or maybe I could have switched to SMC3."
    Grigory's 6DOF #2 -- compact and no linear actuators, 220V servos
  9. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    My 2 cents. I went with encoders, Kangaroos and 2x32 Sabertooth right from the beginning. Just wired up my last 2 encoders tonight for my 6 dof rig.
    Pros for Kangaroo- they can be driven off the motors.(less congested)
    doesn't seem like much, but when I need to make changes on all 6 motor. I don't need to disturb all my control wiring. even then it's mostly plugin!
    Had jittery control when I started out. Thought it was a bad Sabertooth. Just needed to plug the sabertooth into the computer on it's own and reprogram it with DEScribe software. Thanks Carol!
    https://www.xsimulator.net/community/threads/the-in-progress-brig-seat-1-3.12189/
  10. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    I'm switching to contactless potentiometers on my linear actuators ...
    I was considering going for a kangaroo, why is it not good with pot ?
  11. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
    I'm not sure about you actuator, but Page 5 of the Kangaroo manual explains the differences.
