Question DIY clutch paddles
Discussion in 'DIY peripherals' started by The Walker, May 17, 2018.
  1. The Walker
    The Walker New Member
    Italia
    92Coins
    I wanted to build my own F1 Steering Wheel. The wheel itself is not a problem, I know what to do, but I want to add a pair of clutch paddles like a real F1 wheel but I don't know how it works. What do I need? A potentiometer? Is there a guide?
  2. Ads Master
    Ads Master
  3. Fernando Igor
    Fernando Igor Member
    Programmer
    Fortaleza, Brazil
    884Coins
    DC motor, Arduino
    - 2 potentiometers (or other component with the same function) to have independent function
    - a microcontroller (Arduinos [atm32u4] .. stm32 .. PIC ..) that will work as a joystick and
    - programming in the microcontroller to have what you want, like parallel or combined potentiometers ...
    (There should be some component / circuit to parallelize the potentiometers and give the effect of 1, but the easiest way if you want to build one from scratch and if you have any knowledge of programming).
    - Another way is to create some physical model (with gears, limiters, and springs) that can reproduce the effect of just one potentiometer, and that is normally connected on a joystick board like any other axis.
    If you want to learn / use microcontroller, there are several projects already created and open source joysticks, implementing only the change of potentiometer readings in parallel
  4. stashy
    stashy New Member Gold Contributor
    india
    - 24Coins
    2DOF, SCN6
    hi any links for the open source projects?
  5. Fernando Igor
    Programmer
    Fortaleza, Brazil
    884Coins
    DC motor, Arduino
  6. dualin
    dualin New Member
    Cáceres - Spain
    67Coins
    I think that you need only a potentiometer, there is a commercial one that works only with 1 pot. Is the Martin Asher one. I have seen it and has one pot and a little board with some connections and 3 resistors.
    Regards
  7. lysa elec
    lysa elec LYSA ELEC
    161Coins
    thanks for the titurial
