DIY 2DOF 360 Flight Simulator
Discussion in 'DIY Motion Simulator Projects' started by Tony Doueihy, Aug 22, 2017.
  1. Tony Doueihy
    Tony Doueihy New Member
    Lebanon
    151Coins
    2DOF, DC motor, AC motor, Arduino
    Hello Everyone,
    This is my first post in this forum and I am hoping that I will be able to get some help.
    I am making a 2DOF 360 Flight Simulator similar to Fly Motion Flight Simulator and so on.
    I have finished the Solidworks Design and everything related to that.
    If you want to know really what project I am trying to do please check these 2 videos:
    I am having a problem choosing the correct motors for my projects.
    Should I go for 220V AC with VFD or 12V/24V Servo?
    Both motors should be able to do a full rotation with position precision control.
    What should I choose?
    Before choosing the correct power and torque I need to narrow my choice in choosing the motor at first step.
    Waiting for your help!
    150,620Coins
    +11,018 / 55 / -2
    360 degree simulators are often discussed but rarely built as they are both complex and comparatively expensive to build, plus have some unique safety issues that need to be addressed.
    It would be a good idea to first build a working model before committing considerable time, money and resources that such a project would take: http://www.xsimulator.net/community...o-driven-model-to-test-your-design-ideas.136/
    There are some existing 360 degree discussions and somewhat similar member projects that may serve as a guide:
    https://www.xsimulator.net/community/threads/prototype-pitch-roll-full-rotation.5804/
    https://www.xsimulator.net/community/threads/360-degree-flight-simulator-home-build.7011/
    https://www.xsimulator.net/community/threads/6-dof-with-360-roll-and-pitch.8307/
    https://www.xsimulator.net/community/threads/360-degree-flight-simulator.8956/
    https://www.xsimulator.net/community/threads/360-degrees-sim.6687/
  3. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    Hi Tony
    I would definitely go with AC motor as they are cheaper than DC in Lebanon even with a VFD
    Marc
  4. Tony Doueihy
    Lebanon
    151Coins
    Thanks for your reply Marc!
    Any idea how can I do positioning control for an AC Motor?
    Like in this video:
  5. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
    Don't think that you will be able to manage a 360 with SMC3 unless you are willing to change the sketch
    A hall pot will do the trick
  6. M.a.t
    M.a.t New Member
    mecanic
    - 11Coins
    hello
    have you finished your simulator?
    150,620Coins
    +11,018 / 55 / -2
    @Tony Doueihy has not been active for 6 years.
