Connection vfd
Discussion in 'SimTools compatible interfaces' started by zapata_h, Apr 11, 2019.
  1. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
    Could a direct connection be made between arduino smc3 and a variable speed drive?
  2. BlazinH
    16,678Coins
  3. zapata_h
    España
    308Coins
    Thank you for your answer, I have seen that plate several times, but I do not see myself able to build it, so I asked if maybe there was another way such as modbus or rs485 / 232
  4. dddman
    dddman New Member Gold Contributor
    193Coins
    If you mean controlling a VFD with an arduino, you can, but not directly. You would need an operational amplifier, a 12V supply and probably a transistor (with a couple of resistor around it) to be able to scale your analog 5V voltage to analog 0-10V needed by the VFD. Also keep in mind that an arduino doesn't do analog output, it's a PWM that simulate a lower voltage (think of switching the light very fast, the total lominosity will seem lower).
    Pretty simple when you can do hand soldering on a proto board. I can help if you need.
    [reviving old treads! yeah!]
  5. zapata_h
    España
    308Coins
    Thanks for your answer, the board to convert the 0-5v to 0-10v for the speed reference I have it working ok, the problem is that if I try to connect the outputs of smc3 dir1 and dir2 I can not get the inverter to work, I guess the solution will happen to use the speedy plate
  6. yobuddy
    51,388Coins
  7. zapata_h
    España
    308Coins
    Right yobuddy, I have transistors placed, I've already managed to make it work
  8. zapata_h
    España
    308Coins
    I have a problem when trying smc3 in mode 1, using vfd, it turns out that when I connect motor 3 I see that it does not work correctly, I see the value of Fpwm is 4-31khz, if I connect in motor1 or motor2 it works perfect with 25khz, but when connecting in motor 3 it does not work with 4khz-31khz, what could be happening? I use vfd schneider atv12
    153,101Coins
    +11,117 / 56 / -2
    I do not know what the issue is but for a simple solution why not use another Arduino for the third motor.
  10. zapata_h
    España
    308Coins
    I was thinking about that, but then engine 3 only works with 12 / 24vdc engines ?, I'll make another plate and add another arduino just for that engine
  11. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Hello,did you build the EZ board to convert the pwm to 0-10v?What did you use for the direction wires connection?Thanks
  12. zapata_h
    España
    308Coins
    Hello friend, if I built a PCB to convert the 0-5 PWM to 0-10v, but then I replaced the drives with those of schneider, which have 0-5v analog input, so it is not necessary to do anything with respect to the pwm, to The question about what I used for connection cables is not exactly what you mean, I built my own PCB on which I have arduino placed
  13. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Thanks for getting back to me,I was talking about reverse/forward from arduino board,do you connect directly to vfd drive forward and reverse?
  14. zapata_h
    España
    308Coins
    Not exactly, with the SMC3 program while the simulator is at rest, all the arduino outputs are high, which means that the drive is blocked by having the Run command in advance and backward, what I did was make my own board to reverse those signals and stay low
  15. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Okay thanks,think this is way over my head.
  16. zapata_h
    España
    308Coins
    You're welcome friend, any questions that arise do not hesitate to ask, surely in the end you get it, encourage!
  17. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    HI,do you have a circuit diagram for the transistor circuit for direction signal for the vfd?
  18. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Sorry got it sorted.Thanks.
  19. zapata_h
    España
    308Coins
