besoin d'aide
Discussion in 'New users start here - FAQ' started by nicow12, Nov 25, 2017.
  1. nicow12
    nicow12 le rallye, bien plus qu'une passion... Gold Contributor
    rallye karting
    aveyron
    125Coins
    2DOF, Motion platform
    je veux faire marcher mon simu 2dof mes je comprend pas comment y arriver.
    jai acheter le pack a 59euro mes je comprend pas ou et comment arriver a faire les reglage ect...
    merci
    151,383Coins
    +11,036 / 56 / -2
    You can dual language post but it is a forum requirement that you include English via Google Translate, particularly if you are seeking help: https://www.xsimulator.net/community/threads/forum-rules.9527/
    For your convenience if I have do that for you here:
    i want to run my simu 2dof my i do not understand how to get there. I bought the pack at 59euro I do not understand or and how to get to adjust the settings ect ... thank you
    You firs need to understand the relationship between SimTools, the software here, and Xsimulator, which supports the community: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    The Xsimulator Unlimited Premium access package helps support the community and gives you unlimited access to plugin downloads and removes all advertising on XSimulator permanently without any time limitation.
    Members without ab access package can still get access to plugins via earned forum activity coins: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    The licensing of SimTools itself is separate from the Xsimulator Unlimited Premium access package, and SimTools has different licenses to cover DIY and commercial use: https://simtools.us/license/
    There is an eligibility criteria but those with DIY projects can qualify for a free DIY SimTools license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the testing phase.)
    • Have been a member of the community for at least 30 days.
    In addition the demo version of SimTools 2 has a fully operational copy of the Live For Speed plugin, specifically for the purpose of testing: https://www.xsimulator.net/simtools-motion-simulator-software/
    The FAQs are the best place to start when looking for information: https://www.xsimulator.net/community/faq/
    There is a SimTools FAQ section: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    It includes links to the manuals and how to create and refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Be aware that when setting up the difference from SimTools 1.3 to SimTools 2 is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
    You will not need the b grouping.
