value1
Automobilista 2 Plugin 2020-04-05
SimTools game plugin for Automobilista 2
  1. value1
    14,263Coins
    Automobilista 2 Plugin - SimTools game plugin for Automobilista 2
  2. chbruns
    chbruns New Member
    147Coins
    2DOF, SCN6
    Hello
    the plugin will still be active after the next updates of Ams2?
  3. chbruns
    chbruns New Member
    147Coins
    2DOF, SCN6
    how many coins for download the plugin?
    154,262Coins
    +11,177 / 57 / -2
  5. Grand Strate
    Grand Strate New Member
    - 45Coins
    Hello @value1
    thanks for the plugin.
    I have a problem, that doesn't work for me by respecting your instructions.
    The plugin is well patched in simtool.
    In AMS, memory and UDP are correctly on Project cars 2.
    Is there anything else to make it work ?
  6. steve white
    steve white New Member
    - 55Coins
    3DOF, Motion platform, 4DOF
    does this work with the ams2 beta program install?
  7. kevinmarz
    kevinmarz Member
    346Coins
    "-ui:pcars" Sorry, I can't get it to work either,Am I suppose to add ("-ui:pcars" )In properties of the EXE file/ local files..Cause I did .Game say's it's running in Simtools..But still no/motion..
  8. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Yes it works with both, you only need to patch one version and it’s works fine on both
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    No need anymore just patch game with plugin then run AMS2 >options >system them enable shared memory
    I’ve set the 3 options
    Project cars 2
    Project cars 2
    Then motion should work
  10. kevinmarz
    kevinmarz Member
    346Coins
    Can you please share the latest version...I got version 2.0.02..I did everything ..with no results..I got D.o.f reality and I think I have a older Plugin...Thank you
    154,262Coins
    +11,177 / 57 / -2
  12. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    As @noorbeast said there’s no plugin sharing, but I believe there’s only one release out (are you using AMS 1 or AMS 2 plug-in ?
  13. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,510Coins
    The current AMS2_GamePlugin for DOFReality is working for me. The one thing I had to do other than patch the game to get things working was create a Max/Min file in tuning centre. Unlike some of the other older games, AMS2 had a default of all the values at zero which will create no movement.
    • Like x 3
    • Agree x 1
    • Winner x 1
    • Informative x 1
    • Useful x 1
  14. kevinmarz
    kevinmarz Member
    346Coins
    Thanks for the reply…@GWiz… Thank you… It's working… Thanks for telling me that..hug:
  15. kevinmarz
    kevinmarz Member
    346Coins
    Compared to PC2 the movement just isn't there...anyone with Dof Reality h3 ..be kind enough to share your simtool setting's...most i'm getting out of AMs2 is traction loss...no roll,no pitch etc...
  16. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    If your Pcars 2 profile is good just copy the settings from that :thumbs
  17. chbruns
    chbruns New Member
    147Coins
    2DOF, SCN6
  18. chbruns
    chbruns New Member
    147Coins
    2DOF, SCN6
  19. Zeroselect
    Zeroselect Member Gold Contributor
    Maryland, USA
    111Coins
    4DOF
    Until they fix the grass and gravel I have had to kept my settings down. It will shake the fillings out of your teeth.
  20. kevinmarz
    kevinmarz Member
    346Coins
    I got hit from behind me so Hard testing motion,I felt like Emilio Estevez when he went into the wall in the movie Freejack...Hahaha
