Genre: Sim racing
Motion Data:
This plugin provides pitch, roll, yaw , surge, sway & heave and Traction Loss
GameVibe:
Supported (RPM, Gear Shift, Collision L/R, Collision F/B, Road Detail, Chassis, Turbulence)
Dash Data:
Speed [km/h], RPM, Gear (-1 = Reverse), Game State, Player, Car, Class, Track, Car Flags, Oil Temp [°C], Oil Pressure [kPa], WaterTemp [°C], Water Pressure [KPa], Fuel Pressure [KPa], Fuel Level, Fuel Capacity, max RPM, Ambient Temperature, Highest Flag Colour, Lap valid
Author: value1, yobuddy
How to activate AMS2 telemetry output:
❉ In steam add the launch option "-ui:pcars" this will allow you to enable UDP and SharedMemory. Its using the exact same data output as PCars2 for shared memory.
❉ once you have enabled shared memory in the system setting using the pcars ui you can then delete -ui: pcars from the launch options in steam to return to the AMS2 ui
❉ Also the max min settings in the Tuning Center.
