value1
Automobilista 2 Plugin 2020-04-05
SimTools game plugin for Automobilista 2
  1. Salvatore21872
    Salvatore21872 New Member Gold Contributor
    Technician
    Australia
    - 96Coins
    Hi i have tried reading all the info and have not being able to make this game run in my Rig simtools recognizes the game that its running but no motion this is the new updated version
    152,694Coins
    +11,090 / 56 / -2
    Please post pictures of all of your setting, particularly the Tuning Center while the game is running.
    You may need to capture Tuning Center Max/Mins.
    See the motion profile refinement tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  3. Salvatore21872
    Technician
    Australia
    - 96Coins
    thanks for your help got it on the first go just needed to Record and save the tuning parameters thanks
  4. SunTzu
    SunTzu New Member
    51Coins
    so what do you have too choose ? in shared memory ?
    152,694Coins
    +11,090 / 56 / -2
  6. SunTzu
    SunTzu New Member
    51Coins
    i followd the instructions ( i had plugin 2.0.0.2) and patcht it
    then in launch option on steam i did -ui:pcars
    then i set shared memory ingame on project cars 2
    udp off
    udp protocol version on : Project cars 2
    then deleted the -ui:pcars
    but it it did not worked.
    sorry i am pretty new in this.
    thanks in advance
  7. Salvatore21872
    Technician
    Australia
    - 96Coins
    After installing the Plugins and manually patching the game, the UDP Protocol version you can change to Project cars 2,
    You need to open the tuning tab in sim tools follow this linked it helped me
    chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/viewer.html?pdfurl=https%3A%2F%2Fsimtools.us%2Fwp-content%2Fuploads%2F2018%2F05%2FTuning-Center.pdf&clen=1137472&chunk=true
    let me know how you went.
  8. SunTzu
    SunTzu New Member
    51Coins
    hi salvatore, thankyou for your response and help.
    i suceed with getting it too work.
    it is now finally active with simtool tuning center and it is capuring max/min and i saved the data.
    my second question is it doesnt feel right yet. is there a sheet somewhere where i can implement better numbers in the Pitch,Roll,Sway,Surge etc ?
    i can not open your file that you sended me.
    i hope too hear from you again
    thanks in advance
    Jordy
    152,694Coins
    +11,090 / 56 / -2
    First grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Then see these tips in the FAQs on how to refine your motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  10. Salvatore21872
    Technician
    Australia
    - 96Coins
    looks like you are going in the correct direction, you need to check if the outputs to the Motors are not reversed, on my Sim when i steered to the right the g-force would be on the Right and when steering to the Left the g-force would be on the Left, that is where the issue is, so i had to set individually set the rotation direction InkedAxis Assignment - DirtRally VR SeatMover V-3 SimTools Page 1_LI.jpg
    Copy and paste the below to a Google chrome browser
    let me know how you go
  11. Salvatore21872
    Technician
    Australia
    - 96Coins
    my advice in the Game engine Axis Assignments set all to zero and try one at a time and play the game that way you will be able to set them accordingly
  12. SunTzu
    SunTzu New Member
    51Coins
    hi Salvatore, i want to let you konw that everything is working finally !
    the hillss feels still littlebit strange if i compare it with acc but in the end..it is fine !
    thanks allot for your feedback!
  13. Salvatore21872
    Technician
    Australia
    - 96Coins
    Hi SunTzu when you are going up hill check the tilt of the rig if it is re-versed then you need to change the Dir section for pitch or increase it need to check that if you go up the hill it needs to tilt back wards if you go down hill it needs to tilt forwards, let me know how you go
  14. SunTzu
    SunTzu New Member
    51Coins
    hi men is it possible too tell me what i did wrong ?
    these are my settings right now.
  15. Salvatore21872
    Technician
    Australia
    - 96Coins
    Hi send me a photo of the rig the way the motors are used
    And try to change the direction of pitch
    I can’t see the settings for roll and heave
  16. Robdog
    Robdog Member
    Newcastle, Australia
    104Coins
    3DOF, JRK
    Since the last update in February I do not have any motion. According to the update log they changed the shared memory, would this require an update to the patch?
  17. Daguru
    Kitchen installer
    Wales uk
    469Coins
    Motion platform
    @Robdog all working here no problems
  18. Salvatore21872
    Technician
    Australia
    - 96Coins
    Have you power cycle your Adreno and the psu, is your psu still working I have had 1 psu fail.
    Does it work with other games
    I don’t have a problem.
  19. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    Thanks for the responses, I still have motion with other games, only AMS2 is a problem. I will check my set up tonight but as I haven't changed anything I am not sure where to look. Do you still have Project Cars 2 selected for shared memory?
  20. Salvatore21872
    Technician
    Australia
    - 96Coins
    Uninstall the patch from AMS2 game manager and reinstall the plugin and reapply the patch then in steam AMS2 start up commands add “-ui: pcars”
    Reboot pc and the Adrino
    Then try running the game from steam, Check that the game manigere changes from colour green to light blue meaning it has detected the game, then redo the tuning process. Let me know how you go
