drtikol's 2 dof Seat shaker
Discussion in 'DIY Motion Simulator Projects' started by drtikol, Aug 1, 2016.
  1. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Getting there, little bit of cutting and lot of learning turning using old lathe but I got things done.
  2. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    axles and potentiometers fitted
  3. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    All the mechanics done(finally, just shy of 5 years anniversary of starting with wiper motors)
  4. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    So it looks like start with electronics won't be so quick as my both JRKs call "No Power" error in JRK app whatever PSU (modded HP 600W PSU),I have 3x PSU and all the same symptoms. Even no sparks from PSU connectors (earth to 12V). Did I blown them all away? Probably, hopefully JRKs are OK.
    153,824Coins
    +11,150 / 57 / -2
    Did you test the PSUs with a Amp Meter?
    If they are modded are you sure you jumped the correct pins?
  6. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Thanks for response!
    Wait a second, I might be making stupid myself. I thought that the pins are for fan to lower RPM and potentially to add Power On switch. I just connected the earth together and 12V. I didn't get from the guide that any pins have to be jumpered to PSU turn on. It actually start fan when i plug it in.
  7. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Where is the facepalm icon..:oops:
    153,824Coins
    +11,150 / 57 / -2
  9. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    That's the guide I have followed but did not realize that need to join pins 6,8 and 10 to Power up the PSU. It¨s running now!
    So in the meantime i ordered additional 2x PSUs on ebay and they were able to ship them this morning:blush
    ANd I have basically undone mods on my other 2x PSU "investigating".
    But one is running, proof of concept is working:thumbs
    Thanks again for quick help here!:cheers
  10. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
  11. Arta Yasa
    Arta Yasa Member
    968Coins
    That is wiper motor sir?? Looks very good wiper, what kind of car that wiper have?
  12. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    I switched to worm gear motors few years back when I got some funds.
  13. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Finally put both controllers togerther.
  14. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Up and running, even able to initial setup of Simtools.
    153,824Coins
    +11,150 / 57 / -2
    Great to see your rig moving :thumbs
    Out of curiosity what is the CTC length of the lever, as it looks large in the video?
  16. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Thanks! Very rewarding to see it moving.
    CTC is actually 55mm.
    Using the test slider in Simtools case the movement a bit "snatchy" . Would I work it by filtering tool in Simtools?
    Thanks for your interest.
    153,824Coins
    +11,150 / 57 / -2
  18. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Thanks again. Need to put some considerable time to tunning as have been too excited about "being alive" so far.
  19. drtikol
    drtikol Member
    Czech Republic
    292Coins
    2DOF, JRK
    Trying to tune profile in Simtools and ion LFS in hard braking one motor just drop down out of range and unable to return to range defined for it. Anyone any idea what causes it and how to solve it? It returns to neutral position when I help it by body movement.
    153,824Coins
    +11,150 / 57 / -2
    The range of levers effectively use of torque is under 40 degrees up or down, over that a lever is very inefficient when it comes to torque utilisation.
    So try restricting your hardware to say 38 degrees up and down. While you are at it check your PID setting to ensure your motors are set to stay in the designated range, while delivering the maximum power the hardware is capable of.
