First steps
Discussion in 'Forum and Website' started by Kenshiro27, Apr 30, 2021.
  1. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Realization of the rear parts and painting To hide the technical part of the simulator and also for the aesthetic side
  2. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    may have incorrectly read the simtools manual but I cannot find how to adjust my motors so that the axis is horizontal (my zero point) to fix the seat plate
  3. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    I plugged two resistor to my sabertooth in order to "burn" the energy when the engines are released.
  4. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Hello
    I finally understood the problem of synchronization with life for speed
    The simtools user manual specifies the fact that it is necessary before patching the game to play a game with it in order to create certain files necessary for the proper functioning of the whole
    But it is not specified that it must be done in a specific mode of the game: SINGLE PLAYER
    I had for my part simple to play in training And it doesn't work so i uninstalled the games reinstalled played in single player and patched the game And it works
    Maybe specifying the fact that it is imperative that the game be played before patching the game before patching in the manual would prevent others from having the same problem.
    Because it took me a long time to find where the error came from
    I let you judge if this information deserves to be noted
    153,890Coins
    +11,154 / 57 / -2
    It is in the FAQs, if we can make that clearer please let me know: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    Which I did point out here: https://www.xsimulator.net/community/threads/first-steps.16082/#post-216630
  6. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    My apologies, it is indeed specified to play in the first person. My reading of English and my eagerness to carry out my project made me miss this precision.:blush
  7. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    How do you adjust the motors manually so that when starting the installation the cranks fixed to the motor shafts are horizontal?
    and therefore the seat
    153,890Coins
    +11,154 / 57 / -2
    If you are using SMC3 the cranks are set to their neutral position on the center line during setup, is that what you did and if so what is now happening?
  9. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    CMC3 is used for an arduino uno
    Personally I use a micro arduino coupled to a 2X32 sabertooth
    153,890Coins
    +11,154 / 57 / -2
    I am not sure if @BlazinH's modified SMC3 code has been tested on a micro arduino.
  11. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    For what I could read and understand the arduino micro is not located in the text
    CMC3 is the only one able to adjust the axes?
    Because I use this base: XPID_SimTools1_6_6motors_2x32_serial_Micro
    153,890Coins
    +11,154 / 57 / -2
    So you are using @Wanegain's code, correct?
    If so I believe your Interface Settings should be CXR, not CX2.
    What guide are you following for @Wanegain's code?
  13. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
  14. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Found in FAQ
    Because I am now trying to find the answer before asking a question because you are kind enough to always answer me although this site already offers a lot of answers
    153,890Coins
    +11,154 / 57 / -2
  16. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    yes I had downloaded the right file. I adjusted the motor by turning the potars by hand
  17. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Having finally succeeded in making the assembly work, I therefore tyransfered all my installation in its final place and installed everything again in my computer tower and the big problems
    My computer is showing me error. Would you have an idea please
  18. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    Sorry I forgot the picture
  19. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    When I press ok the IP address of GAME MANAGER and GAME ENGINE become different and therefore can no longer connect
  20. Kenshiro27
    252Coins
    2DOF, 3DOF, Arduino
    While waiting to solve my computer problems I installed the seat and the belt this morning.We are slowly getting closer to the starting plan / drawing
