Question 6 dof
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by andres50, Jan 30, 2021.
  1. andres50
    andres50 simulador de vuelo (flight simulator 2020)
    mecanico
    pamplona
    - 254Coins
    can someone pass me the arduino code for a 6 dof simulator. I am thinking about my next project. ;)
    153,920Coins
    +11,156 / 57 / -2
    You can use 3 Arduinos with SMC3.
  3. andres50
    mecanico
    pamplona
    - 254Coins
    Some manual on how to start the project 6 dof.Thank you
    153,920Coins
    +11,156 / 57 / -2
    Not a manual, but there are plenty of detailed project builds.
    The FAQs have an overview, but is is a bit dated: https://www.xsimulator.net/community/faq/6dof.22/category
    It would be best to use the Google Search on the Recent page, search for 6DOF, then filter by date, to get the most recent builds, most of which are using servos not Arduinos.
  5. Gadget999
    12,156Coins
    all the answers to your questions are here on the forum - read read and read some more
    one of the first things you will need to decide is if you want to use linear actuators or gear motors
    have you got a budget in mind
    i suggest you build a model 6dof using RC servo motors first
  6. andres50
    mecanico
    pamplona
    - 254Coins
    Hello I am looking for information about motors for my new project 6 dof I have found this motor in aliexpres 35rpm, can it be worth it? if anyone can help me please thank you.
    153,920Coins
    +11,156 / 57 / -2
    If you are going down the DC 6DOF path it is probably a good idea to check out some similar current builds and compare hardware, here are a couple:
    https://www.xsimulator.net/community/threads/in-progress-6dof-compact-and-small-footprint.15166/
    https://www.xsimulator.net/community/threads/im-ready-to-jump-into-making-6dof.15355/
  8. andres50
    mecanico
    pamplona
    - 254Coins
    thank you very much noorbeast i have been researching on the forums and i have seen interesting projects in 3 dof with cardan in the center of the saddle, less motors less headaches.
    153,920Coins
    +11,156 / 57 / -2
    There are other example project but my own compact 3DOF has adjustable heave assist and uses a cardan: https://www.xsimulator.net/community/threads/dx-compact-simulator.5866/
