budget DIY 2DOF Wiper 24V Fiat seicento Seat
Discussion in 'DIY Motion Simulator Projects' started by tadek, Sep 5, 2020.
  1. tadek
    tadek Active Member
    548Coins
    Hi
    I still have a question what the parameter is responsible for
    PWM rev
    150,578Coins
    +11,017 / 55 / -2
    Your question has already been addressed in my previous advice: https://www.xsimulator.net/communit...nd-windows-utilities.4957/page-96#post-207948
    And as per previous advice there are no "magic numbers" to configure SMC3, as it is very much hardware dependent: https://www.xsimulator.net/communit...nd-windows-utilities.4957/page-96#post-207981
    As per the SMC3 instructions: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    PWMrev This is the PWM duty cycle that is used to drive the motors in reverse (hard brake) if they enter the limit zone. Higher values here will brake the motor harder but will draw more current and heat the H-Bridge more. It may also cause an abrupt jolt in your sim as it tries to change direction. Setting this to a similar value as PWMmax would make sense. If you want to disable the revers braking then simply set this value to 0 and the position will be driven by the normal PID algorithm. Settings are in the range 0-255 which are mapped to the range of 0-100% duty cycle.
    Please keep all future questions regarding configuration of your rig to your build thread, as it gets way too difficult for other members to know what has been responded to and what has not.
  3. tadek
    tadek Active Member
    548Coins
    Thank you very very much
    I already understood how I must do. hug:
    Parameters are set to SMC3Utils v1.01 :think
    are written in Arduino?
    Best regards
    150,578Coins
    +11,017 / 55 / -2
    Yes, the Utility writes the settings to the Arduino, so once you are done setting up SMC3 the SMC3 Utility does not need to be run.
  5. tadek
    tadek Active Member
    548Coins
    Hi
    I don't know what it could be caused by.
    After many attempts and failures
    1. I uninstalled Sim Tools 2.5.1 :mad:
    2. I have installed Sim Tools 2.0:confused:
    and everything works great hug:
    best regards
    Tadek
  6. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    I think becuase a faulty file in your %appdata%.. so its now fixed you dont have to update to simtools 2.5.1 LOL
  7. tadek
    tadek Active Member
    548Coins
    Thank you for your interest
    This is how to properly install the latest version of Sim Tools 2.5.1. ? :sos
    How to clean and where it is located %appdata%
    best regards
  8. tadek
    tadek Active Member
    548Coins
    There is a lot of non-linearity and jitter that SimTolls2.0 does not
  9. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    nice !!:thumbs
    but when you are playing try to make brake for the chair wheel to dont fall down LOL ;)
  10. tadek
    tadek Active Member
    548Coins
    cool thanks :cheers
    the wheels do not bother at all, this is the slightest problem at the moment.
    But please help me I can not deal with this problem :blush
    best regards
  11. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    if you delete the appdata for the simtools you will need to install the simtools again and its will look like this is the first time you download its so you need to install the plugin again and register your code again as new pc...
    if you want to make it new press on keyboard WIN + R thin type %localappdata% then you will find folder "SimTools" just delete it and uninstall the old version and install the new one
    hope you get it
    All the best ,
    Absy
  12. tadek
    tadek Active Member
    548Coins
    only found
    SimTools_License
  13. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    oh its mean you just need to go to C:\Program Files (x86)\ and delete Simtools and install after that and then modfiy your setting
  14. tadek
    tadek Active Member
    548Coins
    Hi
    I uninstalled sim tools
    I deleted:
    C: \ Program Files (x86) \
    licenses
    I installed Sim Tools 2.5.1 from 0 and it didn't help
    I have installed Sim tools2.0 again and it's ok
    I don't understand where there may be disturbances
    best regards
  15. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    can you explaine your problem again
  16. tadek
    tadek Active Member
    548Coins
    Hi
    Sim Tools2.0 work super
    Sim Tools 2.5 work very bad
    best regards
  17. tadek
    tadek Active Member
    548Coins
    Hi
    Does the dcs plugin work with Sim Tools 2.0?
    best regards
  18. tadek
    tadek Active Member
    548Coins
    Hi
    I have a licence for Sim Tools 2.0 but it do not work with DCS Plugin
    Could I upgrade licence for Sim Tools 2.5.1 ?
    best regards
  19. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    did you repatch the game ? try to play using another [lane becuase not all plane work with simtools
    150,578Coins
    +11,017 / 55 / -2
    You don't need to upgrade the licence, it covers all versions of SimTools, so just upgrade.
