Keith's 2dof rig
Discussion in 'DIY Motion Simulator Projects' started by Keith, Mar 4, 2020.
  1. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Hi all. I built my race cockpit years ago and have been thinking of adding motion to it ever since. I finally built up the courage to start ordering parts and piecing together. My build is largely inspired by Arielnac's build.
    I have been using a 120" 1080p projector as my monitor but I just recently got the Rift S. Im hoping I can make the Rift S work with motion. Please let me know If you have any experience with this.
    Parts list:
    Motor driver
    Sabertooth 2x32
    https://www.robotshop.com/uk/sabert...MIrYDEu4eG6AIVAdbACh3nmwNSEAAYASAAEgIgbPD_BwE
    Motors
    MY1016Z2
    #Aliexpress C$ 65.27 | 250w 24v 75rpm or 120rpm low speed brush motor, 44mm Longer shaft, Shaft Diameter 17mm , wheel chair used DC gear brushed motor, https://a.aliexpress.com/_Bf7iv2Tb
    Hall sensors
    #Aliexpress C$ 23.05 25%OFF | DC 5V Hall Angle Sensor Non contact Industrial 0-360 Degree Rotation Angular displacement Sensor https://a.aliexpress.com/_d88FkWF
    Gt2 pulleys (2 30 tooth and 2 60 tooth)
    #Aliexpress C$ 1.69 10%OFF | 3D Printer Parts GT2 Timing Pulley 30 36 40 60 Tooth Wheel Bore 5mm 8mm Aluminum Gear Teeth Width 6mm 2GT Accessories For Reprap https://a.aliexpress.com/_dTwiAxd
    Power supplies
    Artesyn 7001138-y000
    Just a heads up. You need to modify these a bit before using.
    https://www.ebay.ca/itm/LOT-OF-2-IB...625335?hash=item51feb4fdf7:g:~rgAAOSwEfBZuvxy
    Bridge rectifier
    [CA$2.43 36% OFF]KBPC5010 1000 Volt Bridge Rectifier Metal Case 1000V Diode Bridge Professional Tools from Tools, Industrial & Scientific on banggood.com https://banggood.app.link/ZGJWvH0kA4
    Arduino Uno R3
    [CA$12.66 19% OFF]Basic Starter Kit UNO R3 Mini Breadboard LED Jumper Wire Button With Box For Geekcreit for Arduino - products that work with official Arduino boards Electronic Components & DIY Kits from Electronics on banggood.com https://banggood.app.link/uyuFr08kA4
    Ball joints
    #Aliexpress C$ 18.04 | 2019 New Rodamientos Rolamentos 4pcs Sq10rs 10mm Ball Joint Rod End Right Hand Tie Ends Bearing Free Shipping Sq10 Rs Sq10-rs https://a.aliexpress.com/_d9ezaVh
  2. Keith
    Keith Active Member
    Electrician
    154Coins
    This is what I have so far. I am still waiting for the motors.
    20200304_055341.jpg 20200304_055356.jpg 20200304_055437.jpg 20200304_060221.jpg 20200304_060247.jpg 20200304_060313.jpg 20200304_060348.jpg 20200304_060416.jpg 20200304_063316.jpg 20200304_063426.jpg
    153,914Coins
    +11,156 / 57 / -2
  4. Keith
    Keith Active Member
    Electrician
    154Coins
    Thanks Noorbeast I will do that.
  5. Keith
    Keith Active Member
    Electrician
    154Coins
    My motors arrived yesterday. The one motor is labeled 500w 220rpm instead of 250w 75rpm. The seller told me it is just mislabeled. We will see.
  6. Keith
    Keith Active Member
    Electrician
    154Coins
    Here are my levers. CTC holes at around 50mm and 70mm. I also drilled out the gt2 pulleys to fit over the motor shafts(17mm)
  7. Arielnac
    Arielnac Member
    Argentina
    240Coins
    :cheers
  8. Keith
    Keith Active Member
    Electrician
    154Coins
  9. Keith
    Keith Active Member
    Electrician
    154Coins
    I added a set screw to the levers. The screw fits perfectly into the notch on the motor shafts.
  10. Keith
    Keith Active Member
    Electrician
    154Coins
    Testing the motors. Should I change the polarity on one of these motors? One is going up and the other is going down.
  11. Keith
    Keith Active Member
    Electrician
    154Coins
    Anybody know? Im moving the 2 axis sliders upwards. One lever is going up and the over is going down. Do I need to change the polarity on one motor?
    153,914Coins
    +11,156 / 57 / -2
    I don't know which axis you have configured in the video, the movement would be OK for sway but not for pitch.
    The DIR check boxes in Axis Assignments being checked green or not determines which way and axis moves and this is how SimTools expects a rig to be configured: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    You can have DIR boxes in a non-standard format but I think it better to switch the polarity and configure the DIR to reflect what SimTools expects.
  13. BlazinH
    16,691Coins
    I didn't know there's a standard format thus the need for dir boxes. Game plugins themselves aren't always standardized either.
    In any case since the motors are following the pots and they're hall pots where you can't reverse polaity you can only use the dir boxes to change directions.
  14. Keith
    Keith Active Member
    Electrician
    154Coins
    Ok. Thanks for the responses Noorbeast and Blazin.
  15. Keith
    Keith Active Member
    Electrician
    154Coins
    My right motor seems to have a second or 2 delay. Any idea why this would happen? Left motor reacts right away
  16. Keith
    Keith Active Member
    Electrician
    154Coins
    I grounded pin 8 on the arduino and changed the baud rate from 500000 to 115200. That seems to have fixed it
  17. Keith
    Keith Active Member
    Electrician
    154Coins
    I got my 150lbs cockpit mounted to the motion platform
  18. Keith
    Keith Active Member
    Electrician
    154Coins
    Doing some testing with live for speed. Not too much movement here. Maybe I need to crank things up a bit
    153,914Coins
    +11,156 / 57 / -2
  20. Keith
    Keith Active Member
    Electrician
    154Coins
    Thanks Noorbeast. Here is another video with more testing. I changed the CTC lever to 70cm
