value1
Codemasters F1 2018 plugin 2.0.1.0
SimTools plugin for Codemasters F1 2018
  1. Domingo Luna
    Domingo Luna New Member
    dominican republic
    - 262Coins
    How do I make it work with the xbox one, someone has tried it.
    151,718Coins
    +11,045 / 56 / -2
  3. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    Thanks yobuddy, i check but it's using 20777
  4. yobuddy
    50,838Coins
    I'm afraid multiple apps can't connect to the same port, no matter what that port is.
    You may be able to set the game with a broadcast Ip address, something like "192.168.0.255".
    But I have not tried it yet.
    Take care,
  5. HoiHman
    Mechanic
    The Netherlands
    331Coins
    From what i have read on the codemasters forum, port sharing should be possible, but i have managed to find a work around by editing the plugin.
    Simtools is now listening to port 20778. Now with simracing proxy server i can have both programs at the same time connect to F1 2018
  6. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Hi HoiHman,
    can you share your proxy server and hardware settings setup please, i like to use simtools, simdash and simhub all together
    thanks
  7. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    Set the ingame UDP port to 20779 and all should be working
  8. Djules
    Djules New Member
    - 175Coins
    DC motor, Arduino, 4DOF
    hello
    How did you change the value of the 27778 port in simtools?
    I have the same problem of communication between simtools and simhub.:think
    Thank you
  9. Octavio Olvera
    Octavio Olvera G4m3r43ver
    Trade Marketing
    Veracruz. Mexico
    65Coins
  10. calabrese
    calabrese New Member
    - 296Coins
    Bonsoir à tous je suis nouveau sur le forum et donc je ne sais pas si c"est le bon endroit pour demander de l'aide je m'explique: j'ai télécharger le plugin de F1 2018 , je patche le jeu mais quand je lance f1 2018 mes verins ne fonctionnent pas par contre pour DIRT RALLY et F1 2014 tout fonctionne dites moi ou se situe le problème cordialement.
    151,718Coins
    +11,045 / 56 / -2
    Please be aware that you can dual language post but it is part of the Forum Rules that you also include English, particularly when requesting help, doing so via Google Translate is fine: https://www.xsimulator.net/community/threads/forum-rules.9527/
    With respect to your issue please post pictures of all of your settings.
    These are the steps to refine a motion profile, in particular note how to capture and save Max/Min values in the Tuning Center: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  12. Karl Thomas Daum
    Karl Thomas Daum New Member Gold Contributor
    - 30Coins
    Hi, I am a noob with using my Motion rig, have it now for 3 weeks. It works great with Iracing, but with F1_2018 it doesnt do anything. Maybe the Problem is that i use F12018 with steam and the Installation path is different, i tried it several time s to patch the game and checked afterwards the game Folders, but i cant see that the game was really patched and the Motion rig doesnt anything, in the Tuning Center there is also no data for F1 during driving. Does anybody knwo what i have to do.
    Thomas
  13. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    621Coins
    2DOF, 3DOF
    You have checked in the F1 options in telemetry settings that this is enable.
    You must have
    UDP telemetry ON
    UDP broadcast mode ON
    UDP IP address 127.0.0.1
    UDP port 20777
    60 Hz UDP send rate
    UDP format 2018.
    Me it works very well.
    Bonjour,
    Tu as vérifier dans les options de F1 dans paramètres de télémétrie que cela soit activer.
    Tu dois avoir
    Télémétrie UDP ACTIVÉ
    Mode diffusion UDP ACTIVÉ
    Adresse IP UDP 127.0.0.1
    Port UDP 20777
    Taux d'envoie UDP 60 Hz
    Format UDP 2018.
    Moi cela fonctionne très bien.
  14. yobuddy
    50,838Coins
    @Karl Thomas Daum,
    First Unpatch the game, then launch the game and complete a race.
    afterwords, repatch the game with Game Manger (patch it in the MyDocuments folder if you on 64bit PC).
    And let me know how it goes buddy!
    Take care,
  15. Karl Thomas Daum
    - 30Coins
    Thank you very much that helped :)
  16. Karl Thomas Daum
    - 30Coins
    Thank you, but it was the missing Settings for telemetry, now everything is working fine :)
    151,718Coins
    +11,045 / 56 / -2
    I have added your in-game settings advice to the FAQs: https://www.xsimulator.net/community/faq/codemasters-f1-2018-required-in-game-settings.333/
  18. Edison Guerrero
    Edison Guerrero New Member
    45Coins
    Hi, I'm new with this simulator, I'm designing a DOF3 simulator, with an arduino one driver, I'd like to install plugin f1 2018 but I could not download what I should do. thanks for your help
  19. value1
    15,009Coins
  20. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    Hi Guys!
    Is it possible that this plugin is not working with the lastest version of SimTools (v2.4)
    Do You have any idea how I can make it work with this version? :grin
    Thank You!
