2DOF - Elite Dangerous Chair - Oculus Rift
Discussion in 'DIY Motion Simulator Projects' started by F-Zero-One, Apr 29, 2019.
  1. F-Zero-One
    F-Zero-One Member Gold Contributor
    derby, derbyshire
    22Coins
    Hi There, first tie post so thought I'd try and give you some pics.
    Making a chair based on FlyPT(pmvcda) and armpit no weld build
    IMG_8528.jpg 5C9ABAEC-0CE2-4D2C-A20F-58545A64A272.JPG 0254D0E8-22F3-4AE4-BB14-21820BEB59A9.JPG 858F45ED-8263-45BD-BF01-D1E479A1F85D.JPG 4544C8EC-70E5-4A4C-80FC-6EA578F97A6C.JPG 4961EACF-0944-414D-9AC5-4D48AFA14989.JPG 597298EF-2591-4368-B3FF-4AFD121B1DE6.JPG B1C161FE-5AF9-43BF-9172-0824A61FA9E7.JPG IMG_8528.jpg IMG_8529.jpg
  2. F-Zero-One
    derby, derbyshire
    22Coins
    Oh and here's the landrover drive shaft
  3. F-Zero-One
    derby, derbyshire
    22Coins
    Mores pics of the aluminium frame to attach to back of seat, I 3d printed some brackets to attach them together, and the aluminium tubes arrived today, so will be adding them to the actuators.
  4. F-Zero-One
    derby, derbyshire
    22Coins
    Ok, I'm back, been away, the motors will arrive tomorrow, and the final pieces have arrived to at least finish the actuators before wiring so this next couple of weeks will be interesting. I'll try and add pics of the progress.
  5. ghidossi
    ghidossi Member
    - 12Coins
    3DOF, Arduino
    great work and i love elite dangerous.
    how long did you work to have this chair ?
    do you have nice sensation when you play ?
  6. F-Zero-One
    derby, derbyshire
    22Coins
    Its not mobile as yet, I am doing this one thing at a time, also moving house, so I am not spending too much cash on it right now.
    There chair as is only cost about
    £50 approx to build, 15 for cushions of ebay, 15 for OSB board, and 15 for base(2x4 wood) and 5 for the drive shaft from landrover(ebay).
    I have just made some PCB of the wiring diagram using https://easyeda.com/ check it out its really quite good. I got the hang of it in about and hour, by looking at others examples and was then pressing purchase my PCB lol
  7. ghidossi
    ghidossi Member
    - 12Coins
    3DOF, Arduino
    thank you to answer me.
    For actuators, you make it by yourself ? what motor did you choose and what is the speed and torque of linear movement ?
  8. F-Zero-One
    derby, derbyshire
    22Coins
    look what arrived today, whoop
  9. F-Zero-One
    derby, derbyshire
    22Coins
  10. F-Zero-One
    derby, derbyshire
    22Coins
    Not much progress as I have been moving house, but here's some pics, the actuators are just about finished just need to add limit switches and cables, then I'll be fitting to chair and then moving onto the electronics
  11. F-Zero-One
    derby, derbyshire
    22Coins
    New pics just the soldering of the pcb with the esp32 and level shifters. and the start of a cable. the I'll be ready to built the PSU.
  12. F-Zero-One
    derby, derbyshire
    22Coins
    Ok I'm back, was busy with other projects, I have now finished the cables from the actuators and am getting ready to cnc the front and back panels for a power supply box. I have also re done the PCB and new ones are on the way to me as we speak, I will test them this time as there were a few cut and paste issues(user errors ;) ) but I did check the diagram three time before submitting the pcb drawing, so we will see, this is based on FlyPT(pmvcda) rig, so if you would like the pcb drawing to get your own made let me know.
  13. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    Hi ,
    Let me know if your actuator work .
    I have some problem with limit swith diagram, see there : https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/page-19
  14. F-Zero-One
    derby, derbyshire
    22Coins
  15. F-Zero-One
    derby, derbyshire
    22Coins
    Here is a schematic of the motion control board by FlyPT(pmvcda) I think someone can check wiring if you like.
    This was done using https://easyeda.com very easy.
  16. F-Zero-One
    derby, derbyshire
    22Coins
    new pcb boards arrived today made cables at the weekend and connected to the drivers, now I need a PSU.
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    You are really doing everything by yourself, wow!
    For the PSU, Led PSU is the way to go. They are a bit more expensive, but they are trouble free.
  18. F-Zero-One
    derby, derbyshire
    22Coins
    Finally
  19. F-Zero-One
    derby, derbyshire
    22Coins
    Now just to attach to chair and then, start playing with sim software.
  20. F-Zero-One
    derby, derbyshire
    22Coins
    Almost there
