Showroom FlyPT - 6DOF Brushless DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by pmvcda, Aug 29, 2017.
  1. luky_90
    luky_90 Member
    276Coins
    As I wrote above it is still in the testing phase, when I assemble the second I will try to make a guide, I will also include the printed parts
  2. Erik Green
    Erik Green Member
    347Coins
    Hello FlyPT;
    What rpms are you seeing with your actuators? Do you feel that actual power output vs. top end rpm is more important for your actuators response?
    Erik
  3. luky_90
    luky_90 Member
    276Coins
    should I connect only 2 actuators on this scheme I can do it?
    can someone help me?
  4. pmvcda
    15,583Coins
    Yes, you can.
    Just ignore the wiring for the third one, or don't connect the actuator.
  5. pmvcda
    15,583Coins
    I have to look back...
    Somewhere in the posts there's some calculations.
    But, my motors can go up to 3500 rpm rated speed (4500 without load)
    I'm using an sfu 1605, that's 5 mm on each turn so:
    3500 rpm * 5mm = 17500 mm/min = 291 mm/s
    Torque vs Speed? There's a good topic from @Dirty with an Excel table to calculate those things. Take a look here with that and some more info for linear actuators: https://www.xsimulator.net/community/faq/diy-linear-actuators.248/
  6. Erik Green
    Erik Green Member
    347Coins
    I guess I phrased that question poorly.
    What I should have asked:
    Do you feel that the overall actuator speed using the BLDC 8015A + 57BLF03 motor/controller combo you suggested would be sufficient for F1/GT type simulations?
    Will be using the same SFU 1605 leadscrews.
  7. pmvcda
    15,583Coins
    In my opinion, it's enough.
    Most of the movement is short travels. That's a good speed already, unless you put to much weight on the platform.
  8. Erik Green
    Erik Green Member
    347Coins
    That is what I was trying to determine: is power for acceleration in short bursts more important than top end speed? Makes sense to me that that would be the case.
    Erik
  9. luky_90
    luky_90 Member
    276Coins
    I couldn't load the sketch into the ESP32 board then seeing other videos I saw that while I was loading the sketch I had to hold the boot key right?
  10. pmvcda
    15,583Coins
    Never uploaded a sketch pressing the boot key.
    Maybe it's a good idea to boot before uploading. But don't keep it pressed.
    ...Unless they made some changes to the software...
    That's a strange one. Are you sure you are using the correct port?
    Drivers installed?
    Do you have the last version?
    Try changing USB port on the PC.
    Be sure there's no other program running and connected to that port (FlyPT Interface)
    Look at the video here: https://www.xsimulator.net/communit...hless-diy-actuators.10799/page-10#post-171762
    Any error message?
  11. luky_90
    luky_90 Member
    276Coins
    hi guys, my engine has wires with different colors do you help me?
    for the signal it has:
    black will be connected to black
    green will be connected to green
    blue will be connected to blue
    yellow to which thread of the scheme I connect it?
    red to which thread of the scheme I connect it?
    for the power I have
    blue, green, yellow how do I connect them?
    the problem with the ESP32 seems to be solved thanks
  12. pmvcda
    15,583Coins
    What motor are you using? Reference?
  13. pmvcda
    15,583Coins
    Sorry, it's a 57blf03 (looked back on the topic). Give me a minute
  14. luky_90
    luky_90 Member
    276Coins
    [Quote = "pmvcda post: 177.986, membro: 4322"] Cosa motore stai usando? Riferimento? [/ QUOTE]
    57BLF03
  15. Erik Green
    Erik Green Member
    347Coins
    BLF motor. Hall sensor: red=supply power black=ground, sensor s1,s2,s3=yellow, green, blue. Power phases UVW=yellow, green, blue.
  16. pmvcda
    15,583Coins
    Your motor:
    My motor in the schematics:
    So I think it's:
    my Hall red = your Hall red
    my Hall blue = your Hall yellow
    my Hall green = your Hall green
    my Hall white = your Hall blue
    my Hall black= your Hall black
    my Current yellow = your Current yellow (phase U)
    my Current red= your Current green (phase V)
    my Current black = your Current blue (phase W)
  17. Erik Green
    Erik Green Member
    347Coins
    Comparing the Nanotec to the Long 57BLF03. the BLF has 8 poles per phase so slower overall speed but the torque constant is 6.6N/cm vs. 4.4 for the Nanotec so technically should have better acceleration?
  18. Erik Green
    Erik Green Member
    347Coins
  19. Gabor Pittner
    Gabor Pittner Active Member
    Szekesfehervar Hungary
    1,395Coins
    Hi @pmvcda, I decided to rebuild my 6dof rig, ;) I want to change rotating actuators to linear (as always happens with motion rig makers :cool:), but as I watch your (and others) videos they are extremely noisy. Have you been thinking about reduce noise? Do you have an idea what can we do maybe?
    What if I cover open sides of them to close ballscrew?
  20. pmvcda
    15,583Coins
    Covering the sides might reduce noise.
    But it's not as loud as it seems on the video.
    Camera microphone and eco in the garage amplify the sound.
    Rotating actuators are way more silent.
    If you live in an apartment, you might prefer it.
    Also, it can be more compact with some powerful motors.
    Take a look at @Grigory rig, he made the opposite, going from linear to rotating: https://www.xsimulator.net/communit...ct-and-no-linear-actuators-220v-servos.11839/
