My 6DOF project
Discussion in 'DIY Motion Simulator Projects' started by xiatian, Jul 9, 2018.
  1. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Read, is the ESP32 library under that website, there are two folders in 31.7M are empty (AzureIoT BLE) After the above method is installed, open Arduino can see, it is prompted "find invalid library" The upload upload prompts the upload successfully.
    Put 5000 the 2000, put the latter updatePositions(1); (2) delete, upload,
    After the power is turned on, the motor turns very slowly. When the micro switch is pressed, it stops. Set SW2=off, sw1=on, and try several times. aa.png
  2. pmvcda
    15,485Coins
    If I understand, it's working, but slow.
    Try to increase this value to 255 (maximum speed):
    Code:
    #define CALIBRATION_SPEED 50
    to
    Code:
    #define CALIBRATION_SPEED 255
    And see if it's faster (be careful)
    Calibration speed should be lower, maybe 128 is good.
    After pressing the minimum switch it should change direction and look for maximum switch.
  3. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Change 255 and 128 have tried, the speed has changed, press the minimum switch does not respond, press the maximum switch motor to stop, no reversal.
  4. pmvcda
    15,485Coins
    Are you using a level shifter from 3.3V on ESP32 side to 5V for speed and direction on controller side?
    Did you change any internal switch on the controller?
  5. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello: pmvcda
    I tested the voltage of the ESP32, which is the voltage without the connection to the axis, (the code uses 3 actuators), with a 3.3-5 level shifter. xx.png
  6. pmvcda
    15,485Coins
  7. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello there
    3.3V to 5V, there is connection, now the voltage on the ESP32 board is also low. There are 3 lines with only 0.66V output. 2018111.jpg
  8. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello: pmvcda
    Now every time the reset button is pressed, the motor rotates, and the minimum micro switch and the maximum jog do not respond. If the hand touches the wiring under the minimum switch, the motor stops, but does not reverse.
    No changes to the controller
  9. pmvcda
    15,485Coins
    Take a good look at the electronics, it's 2asy to loose something
  10. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello: pmvcda
    I checked the wiring. Now I press the minimum switch, the motor reverses, press the maximum switch, the motor does not reverse, but rotates at high speed.
  11. jinyukang
    jinyukang New Member Gold Contributor
    Jiaxing,Zhejiang,China
    - 224Coins
    SCN6
    I have a similar problem as Xiatian.I do not know what went wrong.:(
  12. pmvcda
    15,485Coins
    Completely forgot about this topic.
    I had some people contact me about some issues, trying to replicate my electronics.
    Be sure that you are using the latest version of the software in the ESP32!
    There are two versions, one that calculates speed on the board and the original one that uses the interface to calculate speed.
    Use this one (speed on the board):
    https://www.xsimulator.net/communit...hless-diy-actuators.10799/page-11#post-172295
    to test the electronics. It's simpler.
    You can even use simtools directly with the serial settings on that post.
    If that one works, then try the other one:
    https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/#post-139682
    That uses the interface to calculate speed. (try with version 1.5 of the interface before the last one)
    In the last link there's also some info about programming the ESP32 on the Arduino IDE. There are some bugs on the library that cause different problems on different versions.
  13. jinyukang
    - 224Coins
    SCN6
    The actuator and controller i used.
  14. jinyukang
    - 224Coins
    SCN6
    Controller electrical wiring.
  15. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Finally I have time to do some work, unfortunately, something went wrong!
  16. xiatian
    xiatian Member
    Xi'an, China
    262Coins
  17. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Change plan,
    Processing parts again
  18. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Reworked accessories
  19. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Hi , 3000 rpm is the minimum ! the best to have is 4000 rpm and with load is about 3500 rpm like mine !
  20. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    08.jpg Two consecutive days
    During the process of using the electric drill, the finger was scratched. Rest for more than a week.
