2 DOF SEAT building
Discussion in 'DIY Motion Simulator Projects' started by Joe Neto, May 21, 2018.
  1. Joe Neto
    Joe Neto Emmett Brown 2DOFuture
    System analist
    São Paulo
    192Coins
    Hello guys.
    the first thing i need say : thank you a lot to youbuddy, racingmatt and RaceRAy
    aproximatly 6 months i have working to build my 2DOF seat.
    i stopped by 4 months for problems ( read money).
    but now i have working twice to complete my own deadline.
  2. Joe Neto
    System analist
    São Paulo
    192Coins
    i read so much without to disturb and started my project, i think wich well so far.
    sorry my english.
    i will send descriptions and photos.
    things you must learn.
    a bit the arduino
    welding for wires and also steel tubes.
    cut metals. ( with safety)
    search before ask ( rsrrss)
    network, software,race games and hardware. ahhh sorry, writing english too... (my problem)
    this last i dont no well.
    reading without stop, archives posted by racingmatt, until understand.
    then i started building.
    the first MOTOMONSTER ARRIVED DEAD. ( i dont know, at moment)
    AND...NOW ? ARDUINO TROUBLES ? WIRING ? MONSTER CHINA ? ARDUINO CODE ? WELDINGS
    NO ! ONLY MONSTERMOTO china...
    I BOUGHT ANOTHER, and this resolved.
    I bought the seat.
    the steel tubes.
    welding machine.
    cutting metals machine .
    and hands on work.
    Then, is not DIY ?
    learn
    learn
    all days learning.
    things you need...
    a batery
    welding the base
    schematic Arduino Monstermoto used
    final mount arduino + Monstermoto
  3. Joe Neto
    System analist
    São Paulo
    192Coins
  4. Joe Neto
    System analist
    São Paulo
    192Coins
    i'm happy with results so far so good
  5. Joe Neto
    System analist
    São Paulo
    192Coins
    Finally welding the base and the seat.
    No rails under the seat.
    I gave the seat single seat car ergonomics, I liked the result.
  6. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi all
    solved problem with getting in and out
    The space was small
    it's working
    • Creative Creative x 2
  7. Joe Neto
    System analist
    São Paulo
    192Coins
    Hello people
    i'm finishing dashboard .
    simhub software is used for now.
    the amber light is PIT
    the green light is ....coming soon.
    i'm using arduino nano and one TM1638 display and android mobile.
    big hug to all
  8. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi all
    A day too much activity.
    The dashboard finally shows green light to unlock
    But since nothing is perfect
    the arduino suddenly stopped ...
    it seems to me that the potentiometer of more than a 360 degree turn.
    tomorrow I will put 2 new
    they were totally damaged
    Can anyone help with this?
    the test without connecting the potentiometers in the motor was ok ...
    thanks any suggestions.
    regards to all
    153,914Coins
    +11,156 / 57 / -2
  10. Joe Neto
    System analist
    São Paulo
    192Coins
  11. Joe Neto
    System analist
    São Paulo
    192Coins
    Can someone help me.
    I no longer receive a VIRTUAL AXIS signal
    It only happens, it seems to me only the initial movement. watch the video please
    When I start LFS it makes two moves and stops.
    txs a lot
    153,914Coins
    +11,156 / 57 / -2
    There will not be Virtual Axis movement until you start something like a hot lap, once you do you should have Virtual Axis data when you click the Virtual Axis tab and then Turned On.
  13. Joe Neto
    System analist
    São Paulo
    192Coins
    [QUOTE = "noorbeast, post: 157828, member: 10786"] Não haverá movimento do Axis Virtual até você começar algo como uma volta quente, uma vez que você deve ter dados do Virtual Axis quando yuo9u clicar na aba Virtual Axis e depois em Turned Em. [/ QUOTE]
    ok, thanks i'll try
    regards
  14. Joe Neto
    System analist
    São Paulo
    192Coins
    now when starting LFS shake it few movements and stopped
    already installed patch
    patch uninstalled
    uninstalled LFS
    installed LFS.
    I d'ont no what do...
    Serial commandas work it.
    Arduino code from RacingMatt.
    anyone ?
    i forget anything ?
    see video
    txs
    153,914Coins
    +11,156 / 57 / -2
    Have you created a Default profile and does your sim move correctly in Output Testing, this is what SimTools expects: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    If not then does the sim move as expected with the Arduino code?
    If Output Testing works as expected did you run a race in LFS before patching it, as that generates some needed files. If not unpatch LFS speed, run a race and repatch.
  16. Joe Neto
    System analist
    São Paulo
    192Coins
    [QUOTE = "noorbeast, postagem: 157952, membro: 10786"] Por favor, poste fotos de todas as suas configurações.
    Você criou um perfil Padrão e o seu sim se move corretamente no Teste de Saída, isso é o que o SimTools espera: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements. 230 /
    Se não, então o sim se move como esperado com o código do Arduino?
    Se o Teste de Saída funcionar como esperado, você executou uma corrida no LFS antes de aplicá-lo, já que isso gera alguns arquivos necessários. Se não remover a velocidade do LFS, corra e corra. [/ QUOTE]
    H Noorbeast
    yes i do...
    3 voltas pós-instalar, um patch novamente
    ok i'll post photos
    txs
  17. Joe Neto
    System analist
    São Paulo
    192Coins
    Hi Noorbeast
    explanation:
    When starting lfs the "GAME MANAGER" does not change to GAME RUNNING".
    if I uninstall lfs and install from and do the "PATCH" it works until reboot.
    but even when this works the seat only moves to the starting position.
    grateful for your help
    The machine is an i5.
    16 GB
    HD SSD
    Radeon R5 230
  18. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    In the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping a or b in SimTools 2 for each axis assignment, like this L<Axis1a>R<Axis2a>
    The DIR box being checked orange or not determines which way and axis moves, they should be set in the Default Profile so Output Testing moves like this: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    And follow these steps to create and refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. Joe Neto
    System analist
    São Paulo
    192Coins
    Ah !!
    Nothing moves at the start of the test when moving the sliders.
    starting position only.
    153,914Coins
    +11,156 / 57 / -2
