Question Not running motor in reverse direction with MM Shield driver
Discussion in 'SimTools DIY Version' started by Prabin Kumar Jha, Mar 5, 2018.
  1. Prabin Kumar Jha
    Prabin Kumar Jha Member
    271Coins
    sure, I am doing the same and let you know.
  2. Prabin Kumar Jha
    271Coins
    i did not find preset for live for speed. Could you please send me?
    151,875Coins
    +11,060 / 56 / -2
  4. Prabin Kumar Jha
    271Coins
  5. Prabin Kumar Jha
    271Coins
    It works with Live for Speed demo, my seat dynamics is responding. Thanks Noorbeast, for your suggestion. Pls. find the screenshot of axis assignments. Further any suggestions, pls. tell me.
    151,875Coins
    +11,060 / 56 / -2
    You don't need yaw for a race sim @Prabin Kumar Jha and deleting that brings your total allocations to what they should be, around 100% total: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Your DIR settings in Axis Assignments look a bit odd and likely the value for sway should be increased and the value for roll decreased but it is hard to be sure unless there is a video of the rig moving that also shows the game screen at the same time.
    I will asked that one of the admins @Historiker, @Pit or @RaceRay please pull all of @Prabin Kumar Jha's posts from here into their own thread, as that is more appropriate to continue addressing setup issues.
  7. Prabin Kumar Jha
    271Coins
    Thanks Noorbeast for suggestion, I will share video with you, once I fix steering wheel setting with this game and also change the value in axis allocations as suggested.
    It was first trail just to run the seat dynamics, now it will be fine tune needed.
  8. Prabin Kumar Jha
    271Coins
    Shaft of one of motors was broken down. Now it is repaired and tried to send the video but due to size limit of file, I could not upload it. Is there any other way to send it to you? please inform me.
    Axis allocation of current settings:
    I have quarries:
    1. I want to log the date of roll, pitch, yaw, heave, sway and surge during the game running. Is this possible? What I have to do?
    2. I wish to interface the game model with Matlab/Simulink to check the dynamic performances.
    3. Instead of code, I want a model in simulink to run the motor as it was done in smc3, is this possible?
    Please reply on these quarries.
    151,875Coins
    +11,060 / 56 / -2
    You can upload your video to YouTube and then insert it into your post like this: https://www.xsimulator.net/community/faq/insert-a-video-into-a-post.257/
    I am not entirely sure what you are trying to achieve with your other questions but there is an Axis Analysis App: https://www.xsimulator.net/community/faq/axis-analysis-app.282/
