First 2DOF Seatmover
Discussion in 'DIY Motion Simulator Projects' started by Martin.Berger, Nov 8, 2017.
  1. Martin.Berger
    Martin.Berger Member
    216Coins
    my Name is Martin and some years ago I started planing my seatmover. The Project was interrupted by my hous-Building-Project but now I wannt to bring my seat to an end.
    I use a shoulder-mount design.
    I use These Motors: some sort of truck wipers.
    I´m not sure finally which Code to use racingmat´s or rufus´SMC3. It depends of using one or two MM
    electronics:
    Arduino Uno3
    2 Motomonster
    HP PSU
    My first test on my desk with Racingmat´s Code was successful.
    <iframe src="https://onedrive.live.com/embed?cid=7E6E5612AD530444&resid=7E6E5612AD530444!7589&authkey=AHWjZ06kjyJTVAg" width="320" height="180" frameborder="0" scrolling="no" allowfullscreen></iframe>
    But now my pots ar doing strange Thing: If i turn one pot both Motors are turning just in one direction. If I turn the other pot both Motors turn in the other direction.
    I hope someone can help me about this Problem.
    Thanks,
    Martin
  2. Seth2Christ
    Seth2Christ Member
    216Coins
  3. Martin.Berger
    216Coins
    Hi
    wich one? All of them?
    Myba someone can explain to me how to bring in pics in a more practical way (embed)
    THX,
    Martin
  4. MarkusB
    4,215Coins
    When opening you links, I get to a page saying that this element does not exist or is not available.
    You should be able to add images with the „Upload a file“ button.
    Videos need to be hosted somewhere else, e.g. youtube, and linked to your posts.
  5. Martin.Berger
    216Coins
    Pictures attached.
    Hope someone can help me!
    153,914Coins
    +11,156 / 57 / -2
  7. Martin.Berger
    216Coins
    Hi Noorbeast,
    yes they are! Any other ideas?
    One more thing: the pots are doing just at the half of the way. 50 % givesignal to the Motor, the otjer 50% do nothing.
    153,914Coins
    +11,156 / 57 / -2
  9. Martin.Berger
    216Coins
    Latest update:
    unfortunatly my moto monsters are destroyed. One by my fault, second maybe by chinese Quality :D
    New ones on the way.
    Good time to produce hardware for my building-partner...
  10. Martin.Berger
    216Coins
    Hi to all of you
    it toom some time to her ne started sitz electronics. Now arduino Mm and Winutil ade doing find.
    BUT:
    is there ans tutorial (beside the "her started") to her simtools and my setup to wirk.
    i did everything like ib the tutorial. But no axis are moving.
    by the way i cannot buy the 1 year plugin license csuse paypal refuses it.
    ans ideas
    thanks martin
    153,914Coins
    +11,156 / 57 / -2
    @RaceRay our admin would need to check the plugin payment issue.
  12. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    simple question... Did you buy right and left side motors, or both the same? I had this problem the first time, I bought the two on one side only ...
  13. Martin.Berger
    216Coins
    So here are some Fotos of my Settings
    153,914Coins
    +11,156 / 57 / -2
    For SMC3 try changing your Interface Settings to: Binary (not Hex)
  15. Martin.Berger
    216Coins
    i´ll give it a try.
    Thanks Noorbeast
  16. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    Have you got your rig moving and if so can you please post some further details about it.
  17. Martin.Berger
    216Coins
    sorry for the late reply.
    No, my rig isn´t moving now. My MM doesn´t work as I want.
    I use SMC3 Code and weiring. But i can get just one Motor to work. 2nd doesn´t.
    I´ve no idea why. I checked it with an other MM. Same Problem. Just motor1 moves Motor2 remains at "off" in SMC3
    I recheked weiring 100 times.
    So maybe someone has an idea
    Thanks,
    Martin
  18. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    Can you please post pictures of all of your SMC3 settings.
    Have you swapped out the motor and control board on the side that does work to rule out hardware issues?
  19. Martin.Berger
    216Coins
    my Settings are the following:
    153,914Coins
    +11,156 / 57 / -2
