My simulator 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by kwak, Jan 17, 2017.
  1. noorbeast
    153,836Coins
    +11,151 / 57 / -2
    Please post picture of all your Interface and Axis settings.
    One person had a similar issue with a borked .NET install.
  2. lilted86
    lilted86 Member
    Malaysia
    489Coins
    yes it is
  3. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Are your motor mounts bending yet? Im not sure those flashing l brackets are going to support those motors once you are under heavy movement. May want to use some thicker l brackets on the opposite side to add stability. Maybe not but I would imagine you will see flex over time and this can cause issues depending on how you mount your POTS.
  4. kwak
    kwak Member
    - 324Coins
    With the translation I understand not too much the answer :(
  5. kwak
    kwak Member
    - 324Coins
    153,836Coins
    +11,151 / 57 / -2
    You have not said what code you are running on the Arduino.
    In the settings you have not specified the ComPort.
  7. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Let me guess ... you have a windows 10 ?
  8. kwak
    kwak Member
    - 324Coins
    Yes I put the port on the picture there is not it was a test
  9. kwak
    kwak Member
    - 324Coins
    Yes why ?
  10. kwak
    kwak Member
    - 324Coins
    I just noticed that my picture was bad sorry thank you
  11. kwak
    kwak Member
    - 324Coins
    I still install simtools v2 and on output testing engines run and gamemanager stays on not connected i understand more
  12. speedy
    Alexandria , Egypt
    7,948Coins
  13. kwak
    kwak Member
    - 324Coins
  14. kwak
    kwak Member
    - 324Coins
    Simtool does not keep the settings in interface settings
  15. speedy
    Alexandria , Egypt
    7,948Coins
  16. kwak
    kwak Member
    - 324Coins
    I tried and it does not work I do not know what to do :(
    153,836Coins
    +11,151 / 57 / -2
    @MWB ended up reinstalling Windows as it was the problem, not SimTools.
  18. kwak
    kwak Member
    - 324Coins
    Yes I think it's gonna end like this :( But I would have liked to find the problem
    153,836Coins
    +11,151 / 57 / -2
    With @MWB it looked to be something that confused Windows into mixing localhost with its IP.
    So if it is the same issue start looking at network configuration and anything that may be affecting it.
  20. kwak
    kwak Member
    - 324Coins
    I did a network reset and the problem remains the same I disabled the firewall too and the same
    I just put another pc for the game engine is it works my gamemanager is connected, it does not help me because I would like a single computer
