Why I can not play in dcs?
Discussion in 'Digital Combat Simulators (DCS)' started by cityparker, Oct 4, 2020.
  1. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    plugins version is 0.05,DCS version is 2.5.6. play in VR.
    but No motion output.
    153,053Coins
    +11,117 / 56 / -2
  3. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    [引用=“noor猛兽,帖子:206547,会员:10786”]有许多不同的dcs插件,这是您正在使用的吗?Https://www.xsimulator.net/community/threads/digital-combat-simulator-–-dcs-plugin.4762/
    Can you please post pictures of you Axis Assignments and the Tuning Center while DCS is running.
    The Game Manager indicator being blue means that Game Manger has detected a patched game has
    started, so I suspect it is a configuration issue or something else is interfering.[/QUOTE]
    Thanks,But I have the game of Official copy.I have captured this pictures below.
    153,053Coins
    +11,117 / 56 / -2
    [​IMG][/QUOTE]
    The plugin is working correctly, but your Tuning Center Max/Min values are all set to zero.
    See the motion refinement tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    In particular capturing the Max/Min values: http://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/
  5. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    In particular capturing the Max/Min values: http://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/[/QUOTE]
    THank you very much,It is useful!
  6. Dirty
    All the way up front.
    7,964Coins
    Hey :)
    latest version is v0.09.
    I recommend using that, because
    1) The export scrip no longer interferes with other scripts in DCS
    2) Basic GameVibe and GameDash support
    3) Can be installed via SimTools' PluginUpdater
    4) Does no longer interfere with the original plugin.
    You can ask for help anytime :)
  7. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    thanks very much,but why no export.lua
  8. Dirty
    7,964Coins
    The Export.lua file is a single file that contains LUA code. That means, as soon as you use that file for data export to an AddOn, no other AddOn can use it.
    You can, of course, let that file do multiple things if you can integrate the code from different AddOns into a single file, but that requires at least a basic understanding of what you're doing. For non-programmer users, even with very simple AddOns this will fail 99% of the time.
    Using the callbacks in the "Hooks" folder is a bit more troublesome for the AddOn programmer (no error logging, need to reboot), but the great advantage is that there can be multiple files inside the Hooks folder. Each dealing with it's own AddOn.
    Bottom line: It reliefs the user from having to understand what he's doing. Just copy the file there and you're good to go
  9. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    But I dont konw how to set the simtools good in dcs with my 2dof.
  10. Dirty
    7,964Coins
    I don't either :)
    If those 2DOFs are pitch and roll, then I would probably use...
    rollrate-->roll
    pitchrate-->pitch
    ...to start with.
  11. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    I mean that if the plane is rolling left ,and the chair should truning right, like the car? and vice versa.
  12. noorbeast
    153,053Coins
    +11,117 / 56 / -2
    The DIR box being checked orange or not in the Axis Assignments determines which way each axis moves, see the SimTools manual: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    This is the convention for SimTools axis settings: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  13. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
  14. Dirty
    7,964Coins
    With a 2DOF it's hard to get good motion.
    In a car I would tilt the rig left during a right turn and vice versa.
    In an aircraft I would tilt it left while starting a left roll. Use a high pass filter for that.
    And play around. Trial and error will get you far.
  15. noorbeast
    153,053Coins
    +11,117 / 56 / -2
    The basic Axis Assignments layout will be the same for a car and plane, but the allocations and tuning will be different, as per the Tuning Tips links posted earlier:
    In a plane on a 2 DOF roll and pitch are more significant than they are for a car, and simulated heave less important for a plane profile than a car. Same with the Tuning Center, the values for a plane will be much larger than a car profile.
    So read through the tips, initially do each axis one at a time, before finally turning them all on and applying final tweaks.
