Question What am I doing wrong?
Discussion in 'SimTools compatible interfaces' started by Michael Rosenbauer, Mar 22, 2023.
  1. Michael Rosenbauer
    Michael Rosenbauer New Member Gold Contributor
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    Hey guys it is the first time that I write in this comunity.
    I am trying to build a 3 DOF motion sim rig. Mecanical is no problem.
    I have the cabeling plan from this Forum and bought the arduino finaly as TM . The 3 Motorcontroller are IBT 2 versions.
    My 1. try : wiring all the cabels into my "junktion boX" it looks all fine but didn´t work.
    2. try dismantle everything and try it with only one connected IBT2. Surprise surprise I found a way that this Motor works with the SMC Utiliy, but I dont know why! I could not replicate the situation.
    Any way I wired up the Junktion box again with all 3 M-controller, doublecheck the wiring a thousand time but it still is not working.
    So I decided to make sample. 1 New arduino with one new IBT2 wired up. No function.
    I struggle to make this run one time!
    150,578Coins
    +11,017 / 55 / -2
  3. Michael Rosenbauer
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    I am using this drawing and MODE2 is changed, thats why one time the Motor was moving and I could adjust the parameter to well working Actuator.
    150,578Coins
    +11,017 / 55 / -2
    So what happened to stop the actuator that was configured and working well?
  5. Michael Rosenbauer
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    I build in the 3 IBT2 controller in the Box with the arduino and want to do the same config procedure with the other 2 IBT2 and motors. But that doesent work. Then I tryed it again with a new arduino and IBT2 for just 1 Motor preliminary wired outside the junction box. Also without function
  6. Michael Rosenbauer
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    Is there anyting I need to observe? Like the sequence to load up the program to the arduino? Preparing the arduino?
    150,578Coins
    +11,017 / 55 / -2
    Are you using a genuine Arduino, not a clone?
    Are you certain the IBT2s are not damaged or faulty, have you checked the functioning of each one individually, as it sounds like at least one worked?
  8. Michael Rosenbauer
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    The First Arduino was a (Funduino) then I bought the original. Until now I bought 2 original Arduinos one clone and 12 IBT2 Motor controller from different supplyers
  9. Michael Rosenbauer
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    How can I check the IBT2
    150,578Coins
    +11,017 / 55 / -2
    So does the SMC3 code install OK on a genuine Arduino?
    150,578Coins
    +11,017 / 55 / -2
  12. Michael Rosenbauer
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    Yes the arduino was showing the leds and there was no sign that it wasnt proper installed.
    I am currently in Dubai until next week (WORK) I will check the IBT2 according your advice afterward!
  13. Michael Rosenbauer
    Aussendienstmonteur
    Erfurt Thüringen
    56Coins
    Hello Guys, after some turbolent day´s I find the time to check the IBT 2 Bridge Controller with a 2nd Arduino.
    At u tube I have seen a short sketch witch I copied and run this sketch with a very new IBT2 and it worked.
    So I run the "3 build in IBT2" with this short sketch an what should I tell you, they are all done.
    So my goal is to test the new one first and if they are runing they are approved to join .
    Dont get me wrong the 3 installed in IBT2 Controller where not used. So make shure if you buy from some where in China, before you finaly install those IBT´s if they are running.
