Question VTOL VR Plugin Development
Discussion in 'DIY Motion Simulator Projects' started by nebriv, Feb 25, 2020.
  1. nebriv
    nebriv New Member
    58Coins
    Hey all,
    I'm working on developing a plugin for a VTOL VR (VR game available on steam) mod. The mod is injected into the VTOL VR game and outputs telemetry that would hopefully be used for motion simulators.
    Unfortunately I do not own a motion simulator. I was aiming to use YawVR's emulation tool and SimTools to capture and re-transmit the UDP telemetry from my mod.
    Does this seem like sound logic to work from?
    As I do not own any type of motion simulator - I do not wish to buy a license for SimTools. I see there is an alternative "Free" discount code available. Would this be applicable in my situation?
    154,292Coins
    +11,178 / 57 / -2
  3. KydDynoMyte
    RTP, NC
    40Coins
    He already has great data outputting. Shame he doesn't have a way to test the plugin he would like to make for the community.
    154,292Coins
    +11,178 / 57 / -2
    There is nothing posted I can see that indicates what data is outputted. What I flagged for @nebriv is that SimTools has an API.
  5. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    I'm really interested in this project. I feel it's one of the best VR flight sims out there. The immersion with the seat would be amazing
  6. nebriv
    nebriv New Member
    58Coins
    @noorbeast thanks for your reply! I thought about the memory hooks initially but the game is under very active development so the pointers would be constantly changing. I have no problem currently getting basic telemetry output through a UDP stream in game, I've already developed a mod to do just that. It seems to work fairly well. As far as what data is currently outputted, this is what I've got:
    // FORMAT
    //S:timestamp:heading:pitch:roll:x_accel:y_accel:z_accel:took_damage:gun_firing:E
    Unfortunately the current sticking point for me is getting the data ingested into SimTools - I targeted SimTools as it seems to be the most popular tool available for people with motion simulators. Currently the demo of the software only seems to support LFS and I am unable to develop a custom plugin to support the data output from my telemetry plugin within VTOL VR. As I mentioned above, I unfortunately do not own any motion simulator so I don't really have much incentive for spending money on the tool. Is there anyway to develop and test custom game plugins without purchasing the full software?
    I'm more than happy to spend my time developing a plugin for free for the community.
  7. nebriv
    nebriv New Member
    58Coins
    I don't seem to be able to edit my post - output data without emojis! :)
    Code:
  8. Terrell Zeigler
    Terrell Zeigler New Member
    42Coins
    Were you able to get anywhere further with this?
  9. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
    I this project still ongoing id like to get involved if there is still no plugin created
    154,292Coins
    +11,178 / 57 / -2
    @nebriv has not been around for about a year, but hopefully will return, so in the meantime another possibility is to use the existing generic Joystick plugin: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
    The generic Joystick plugin functionality can be extended using Vjoy, see the FAQs here: https://www.xsimulator.net/communit...otion-plugin-and-vjoy-controller-mapping.387/
  11. KydDynoMyte
    RTP, NC
    40Coins
  12. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
  13. Map63Vette
    Map63Vette Active Member
    Mechanical Engineer
    Lawrence, KS
    715Coins
    I know this is a pretty old post, but I'm having some issues getting this plugin to even show up in GameManager. I've downloaded the zip from GitHub and used the PlugInUpdater to "install" it and it claims that the plugin was installed successfully, but when I open GameManager to see about patching the game or GameEngine to set up axes, VTOL VR isn't showing in the list. I tried running the game once to see if maybe it just needed some files installed first, but that doesn't seem to have made any difference. Any idea why the game isn't showing in the list?
  14. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
    Did you get a licence for simtools
  15. Map63Vette
    Mechanical Engineer
    Lawrence, KS
    715Coins
    Yeah, I'm running a pro license. I got that to be able to run game vibe. I've got the full system running Assetto Corsa fine, just trying to get it working with other games now.
  16. Map63Vette
    Mechanical Engineer
    Lawrence, KS
    715Coins
    So I think I might have an idea what the issue could be, but I'm not sure how to go about solving it. The zip file I have for the plugin appears to be full of Visual Basic project files, while most of the other plugins are dlls and xml files. I'm thinking I maybe need to build the project into a dll or something? Anyone have any idea how I might go about doing that?
  17. noddyier
    noddyier New Member Gold Contributor
    - 384Coins
    Sorry , but is it any hope ? , any update for VtolVR Plugin
  18. noorbeast
    154,292Coins
    +11,178 / 57 / -2
  19. Map63Vette
    Mechanical Engineer
    Lawrence, KS
    715Coins
    @noddyier Don't know if you're still looking for a plugin, but I believe I've got something working now if you were interested. It requires a different VTOL VR mod to be installed (there is one for a FlyPT Mover on the VTOL VR mod website that you have to use), but I'm getting values in the tuning center of SimTools with it now and was going to start testing it on my actual rig today most likely. Happy to share it to see if it works for you.
  20. JCM
    JCM New Member
    101Coins
    Hi
    I am also trying to get the VTOL VR FlyPT mover plugin to work, without success.
    I can read some data, but its totally messed up.
    Maybe the updates broke everything.
