Question SMC3 - PWMmax value etc. for PGSaw geared motors
Discussion in 'SimTools compatible interfaces' started by Ronan Design, Sep 18, 2021.
  1. Ronan Design
    Toronto, Canada
    1,716Coins
    Hi, I've building my first 2DOF rig. Motors are working, but I'm not sure what should be PWMmax value for my PGSaw geared motors? Tutorial doesn't mention that. Should it be a maximum value (is it 256?) to use all of the motor's torque?
    Tutorial says PWMrev should be same as PWMmax - would it be too hard on the motor? What should I set it to?
    I tested and tuned motors without load first, and they work, but I;m not sure of the values I shoudl use. I set Kp to 400, Ki = 0 (I get oscillations if it's higher), Kp = 0. Anything i should do with those values?
    PWMmin is set to 30 right now and I get a whilte on motors without load. I guess this should be set so the seat does't sag or move with full load at idle...
    I'd appreciate if anyone shared their settings - maybe a screenshot.
    153,890Coins
    +11,154 / 57 / -2
    See the second post of the SMC3 thread, as it explains all the settings: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    PWMmax This is the maximum duty cycle that is used to drive the motors to their target position. As the target position gets further away from the actual position the control loop attempts to increase the motor drive (PWM) to get it to the target position. It will increase the PWM until it reaches PWMmax.
    With respect to PID while this gentle layman's introductory guide was done with JRKs in mind the fundamentals are the same: https://www.xsimulator.net/community/faq/a-laymans-analogy-guide-to-pids-pid-tuning.219/
  3. Ronan Design
    Toronto, Canada
    1,716Coins
    I read it many times, and followed the tutorial when testing. However while ir explains what PMWmax is it doesn't explain how to tune it and what to aim for, nor does it say what's the max value. Does it just affect the max speed of the motor when trying to reach set point, or does it limit the torque? I want to use all available torque when needed, so should I set it to the max, unless it's too fast? And what's the max value then? Or does it only affect the speed and I just should set it to whatever max speed I want? In that case what is a sensible setting?
