SMC3 - brushless DC motors ?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Gadget999, Dec 11, 2018.
  1. Gadget999
    11,941Coins
    I have found some 2kw 48v DC motors that look pretty useful
    they are brushless
    will the SMC3 be able to control a brushles motor ?
    will a special motor driver be needed ?
  2. BlazinH
    16,650Coins
    SMC3 doesn't have a brushless mode but if a brushless motor driver exists that accepts pww and direction or inverted pww signals then it might work with mode 1 or 2.
  3. Gadget999
    11,941Coins
    ok - probably easier to stick with a DC motor and a h-bridge
    has anyone used the SMC3 with ac motors - I assume it needs an inverter with pwm and direction
  4. BlazinH
    16,650Coins
    Agree with first paragraph.
    What do you mean by an inverter? Unless using an ac servo motor with its own controller most use a vfd usually requiring 10 volts which an arduino is incapable of on its own.
  5. pmvcda
    pmvcda aka FlyPT
    Portugal
    15,391Coins
    If you want the brushless route, take a look at my thread: https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/
    The BLDC-8015A can handle 24V to 50V and rated 15A to a 45A peak
    But there are other alternatives.
    Can you give a link to those motors?
  6. Gadget999
    11,941Coins
