Question SMC3Utils question
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Arazok, Sep 2, 2019.
  1. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hey,
    using my rig now since 10 month a strange issue came across:
    When using SimUtils (latest version) the PWMmax values are strange. They are always 16 for Motor1, 17 for Motor2.
    If I change it and write (save image), stop and start SimUtils, the same.
    All others values are fine and correct.
    When checking with Arduino program tool and reading out the PWMmax1 value, it is 140, as it should be.
    But why is SimUtils saying a value of 16 (or overwriting it) ?
    I am using SMC3 with sabertooth code.
    cheers, Arazok
  2. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Ok, it was my fault ! Problem found:
    With some slide changes to the SMC3 softstart code, the PWMMax values are slowly increasing, while SimUtils reads the values. That's why the wrong values (too low) are shown in SimUtils.
    I need to adapt my code :)
    regards,
    Arazok
  3. weld12
    weld12 New Member Gold Contributor
    Mechanical/technical/engineering/scientific
    Portland, Oregon
    166Coins
    Hello Arazok,
    I think I get what your saying; the soft start code is slowly increasing pwm to max so the value represented in the utility may be an initial pwm value that is very low at start up. I don't fully understand the code or why the previous soft start code was not functioning. You've found a way to have it work and show/save real time pwm values "slight changes ;)" That's cool! If you could share I would appreciate it.:thumbs I don't know why others haven't been bothered by this as I like to use the utility at times.
    I thought maybe I had a different version of the utility, when I was experimenting with the smc3 code prior to it be adapted to fit sabertooth/soft start.
  4. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Correct. I will check the code (hopefully) today and post my changes...
  5. RacingMat
    21,068Coins
    "SimUtils" is the rFactor2 plugin which collect data in game for graph and statistics?
    https://simutils.dk/
  6. Arazok
    Arazok Member
    Computer scientist
    783Coins
    I send weld12 a pm with my changes.
    @RacingMat: No SimUtils is the graphical "standalone" Windows tools to test your motors. Can be downloaded somewhere here (in the SMC3 thread) I think.
    153,053Coins
    +11,117 / 56 / -2
  8. RacingMat
    21,068Coins
    @Arazok maybe you should edit the topic title with the correct term ;) SMCUtils
    153,053Coins
    +11,117 / 56 / -2
    Done.
  10. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Done, changed in thread title. Sorry for any inconveniences...
  11. Arazok
    Arazok Member
    Computer scientist
    783Coins
  12. weld12
    Portland, Oregon
    166Coins
    Yes, SMCUtils, that what I was referring to as well.:thumbs
    Thanks to @Arazok, @RacingMat, @noorbeast 's contributions it is easier to follow.
