Simtools v3+Simhub
Discussion in 'New users start here - FAQ' started by jasper soffers, May 5, 2026 at 20:28.
Tags:
  1. jasper soffers
    jasper soffers New Member Gold Contributor
    - 95Coins
    "Hi, I use IL-2 with SimTools v3 (reads IL-2 via memory on port 4123 using addr="127.0.0.1:4123" syntax) + SimHub bass shakers. SimHub shows "game is not configured" unless motiondevice1 is set to port 24321 in its own format. But when I set motiondevice1 to port 24321, SimTools loses motion. How can I run both simultaneously?
    154,639Coins
    +11,206 / 57 / -2
  3. jasper soffers
    - 95Coins
    Thanks for the reply. I tried SimHub port forwarding (SimHub listens on 24321, forwards to SimTools on 4123). SimTools crashes immediately with Access Violation in clr.dll (Exception code: 0xc0000005) when entering the cockpit in IL-2. The IL-2 plugin page shows UDP Relay Supported: False. Is there another way to share IL-2 motion data between SimTools v3 and SimHub without SimTools crashing?
    154,639Coins
    +11,206 / 57 / -2
    When he has a spare moment I hope @yobuddy can chime in re the error.
    In preparation for that can you please expand the error message and post the full result here.
  5. jasper soffers
    - 95Coins
    Sure, thanks!!
    Log Name: Application Source: Application Error Date: 05/05/2026 20:55:24 Event ID: 1000 Task Category: Application Crashing Events Level: Error Keywords: User: GAMEPC\jaspe Computer: GamePC Description: Faulting application name: SimTools.exe, version: 3.0.0.0, time stamp: 0x6840c9d5 Faulting module name: clr.dll, version: 4.8.9325.0, time stamp: 0x693b62aa Exception code: 0xc0000005 Fault offset: 0x002b705b Faulting process id: 0x834 Faulting application start time: 0x1DCDCC0179501A8 Faulting application path: C:\Program Files (x86)\SimTools3\SimTools.exe Faulting module path: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll Report Id: 25f21d44-6c02-432c-9ca4-6ec6eff1ebfc Faulting package full name: Faulting package-relative application ID: Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Application Error" Guid="{a0e9b465-b939-57d7-b27d-95d8e925ff57}" /> <EventID>1000</EventID> <Version>0</Version> <Level>2</Level> <Task>100</Task> <Opcode>0</Opcode> <Keywords>0x8000000000000000</Keywords> <TimeCreated SystemTime="2026-05-05T18:55:24.9408106Z" /> <EventRecordID>97773</EventRecordID> <Correlation /> <Execution ProcessID="28072" ThreadID="21160" /> <Channel>Application</Channel> <Computer>GamePC</Computer> <Security UserID="S-1-5-21-1700521309-394369820-3753783921-1001" /> </System> <EventData> <Data Name="AppName">SimTools.exe</Data> <Data Name="AppVersion">3.0.0.0</Data> <Data Name="AppTimeStamp">6840c9d5</Data> <Data Name="ModuleName">clr.dll</Data> <Data Name="ModuleVersion">4.8.9325.0</Data> <Data Name="ModuleTimeStamp">693b62aa</Data> <Data Name="ExceptionCode">c0000005</Data> <Data Name="FaultingOffset">002b705b</Data> <Data Name="ProcessId">0x834</Data> <Data Name="ProcessCreationTime">0x1dcdcc0179501a8</Data> <Data Name="AppPath">C:\Program Files (x86)\SimTools3\SimTools.exe</Data> <Data Name="ModulePath">C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll</Data> <Data Name="IntegratorReportId">25f21d44-6c02-432c-9ca4-6ec6eff1ebfc</Data> <Data Name="PackageFullName"> </Data> <Data Name="PackageRelativeAppId"> </Data> </EventData> </Event>
