News SimTools v2.3.1 HotFix is out! (Registration Fix)
Discussion in 'News' started by yobuddy, Dec 15, 2018.
  1. yobuddy
    51,399Coins
    If you are having problems registering SimTools, please download SimTools v2.3.1.
    Due to an unplanned update by our web-host, and some new security "features", the registration system reports it can not connect to the internet. :(
    Due to it not being able to connect, we fixed it! :)
    You can download the new version here:
    https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    If you want to register a version older than v2.3.1, please download and unzip this file to your desktop.
    https://simtools.us/wp-content/uploads/2018/12/SimTools_Registration_Update.zip
    And use this updated version to register.
    If you are still having issues, please update your .net framework to the current version.
    Take care, :cheers
  2. weld12
    weld12 New Member Gold Contributor
    Mechanical/technical/engineering/scientific
    Portland, Oregon
    166Coins
    Just registered, after trying everything yesterday, I saw the update on simtools.us
    Thank you yobuddy!
  3. woodzie
    woodzie New Member
    167Coins
    153,143Coins
    +11,117 / 56 / -2
  5. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    I have tried for one hour. cant register because its still says i have no internet connection. This fix dont help me.
  6. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    I’m using a 2 year old version of SimTools
    How is the latest version different ?
    Is it worth messing around with updating ?
    153,143Coins
    +11,117 / 56 / -2
    Updating thisf
    Updating fixes some stuff and also is needed when using the latest companion apps like Game Vibe, but if everything is working ok for you then you don't have to update.
    Updates are pretty simple, straight over the top of the existing install, just say no to writing default values when prompted. But to be certain you can create a backup first: https://www.xsimulator.net/communit...thout-loosing-your-profiles-and-settings.160/
  8. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    What should I do when this fix doesn’t help? Still no internet connection found.
    153,143Coins
    +11,117 / 56 / -2
    Give some further details: confirm the version of SimTools being used, try temporarily disabling any firewall and antivirus, while those are disabled reinstall SimTools and test while those are disabled.
  10. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    I did try that you said. Firewall off and no antivirus.
    Win 8.1 pro
    Tried both 2.3 and 2.3.1. And with registration update.
  11. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    Thanks to yobuddy I finally got the solution. If someone else having problem... for me it was to update .net framework
  12. Giorgio73
    Giorgio73 Alluminium rig with prosimu 3dof kit
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    I have the same problem
    Window 10 pro, internet connection work correctly
    when i go to register.exe i have message non internet connection
    which version of net framework you have now for solve the problem?
  13. Hamreus
    Hamreus Member
    Avesta
    666Coins
    2DOF, SCN5
    I installed .NET Framework 4.7.2 on Win8.1. Maybe its same version on Win10
  14. noorbeast
    153,143Coins
    +11,117 / 56 / -2
  15. Giorgio73
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    ok guys, meanwhile thank you so much for your help.
    I managed to solve the problem.
    to those who may be interested, I indicate what I have done.
    I state that I had the problem on two PCs with different operating systems.
    a laptop with windows 7 pro operating system.
    a gaming PC with windows 10 pro operating system where I connected the dynamic system.
    both of them gave me the wrong connection to the internet.
    Solution.
    for the laptop I updated the net framework to version 4.7.0. problem solved.
    for pc gaming the version of net framework was already updated to 4.7.2, so I uninstalled simtools, I disabled all firewall security checks. I checked out simtools 2.3.1 and finally I managed to do the recording.
    thanks again for the help.
