Question SimTools License
Discussion in 'SimTools Pro & Entertainment Version' started by boomer, Jun 22, 2019.
  1. boomer
    boomer New Member Gold Contributor
    Sydney, Australia
    170Coins
    Hi Guys,
    I have aquestion about SimTools license before i purchase one. Im looking at the pro license and wanted to know if I had re-install Windows again or upgrade my pc and re-isntall everything can the license be re-used?
    I have been getting conflicting answers to this from different sopurces. Just wanted to double check before I go ahead and purchase one.
    Thank.
    154,322Coins
    +11,179 / 57 / -2
    Where are you getting contradictory information from?
    It is possible to reinstall SimTools on a new install.
  3. boomer
    Sydney, Australia
    170Coins
    Hi noorbeast, source was someone that I know that has been using SimTools for a while. It was odd for me as when i heard it. As long as there is no limit in number of times the licennse can be activated then its all good.
    I appriciate your response.
    154,322Coins
    +11,179 / 57 / -2
    There are not unlimited SimTools installs, there are a limited number for the very scenario you outlined, as the license is for a specific computer.
  5. boomer
    Sydney, Australia
    170Coins
    Yeah i understand there could be a limit to how many times it can be installed to cover for any windows re-installs or hardware upgrades. Do you know what the default limit is? I did email SimTools support but I have not heard back. If you know the answer it will be great help for me to make an informed decision.
  6. yobuddy
    51,648Coins
    Reinstalling on the same hardware does not cost an activating and you can safely remove SimTools from you old PC, and then install on the new PC and re-register.
    If you do have any problems, please contact support here: https://simtools.us/contact-us/.
    Take care!
    154,322Coins
    +11,179 / 57 / -2
    Please PM the site admin @RaceRay.
    154,322Coins
    +11,179 / 57 / -2
  9. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    [QUOTE = "noorbeast, post: 180676, member: 10786"] Non ci sono installazioni illimitate di SimTools, ce n'è un numero limitato per lo stesso scenario che hai delineato, poiché la licenza è per un computer specifico. [/ QUOTE]
    Hi noorbeast,
    In the next few days i will change the motherboard of my pc on which i use simtool pro version. What should I do with the license? Is it linked to my MOBO like the Windows 10 OEM license?
    154,322Coins
    +11,179 / 57 / -2
    You will need to re-register SimTools: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
    You can look up your SimTools license number, just log into SimTools.us: https://simtools.us/member-login/
    Use the email you purchased the Licenses with, and if you don't have a password, click reset password.
    If you have any problems with registration then you need to contact SimTools directly for assistance: https://simtools.us/contact-us/
  11. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    perfect Thanks noorbeast
  12. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Hello gentlemen, good day, could someone tell me if the same thing happened to you that happened to me ...
    I have just formatted my two PCs for the games and the control board and when I reinstall the GAMEMANAGER AND THE GAMEENGINE it won't let me use my license ... I understand that if I changed hardware it wouldn't let me use it because it counts as if I were installing it on another pc ... but this time I am installing it on the same hard drives ...
    !!!! because it counts as changing hardware ...
    I already sent the mail to those of SIMTOOLS
  13. noorbeast
    154,322Coins
    +11,179 / 57 / -2
    It is a matter for the SimTools devs and relates to the number of license reactivation times, rather than the hardware.
  14. fastrella
    fastrella New Member
    Argentina
    - 251Coins
    hello. I am also from Argentina. the license allows you three or four installations. Send a message to Rich@SimTools.us explain your situation and may consider renewing the license in terms of reinstallations.
  15. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Thank you very much friend for the answer ...
  16. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, for me 4 activations simtools v2 works great
