Icy7CE
Microsoft Flight Simulator 2020 Plugin 1.1.3.0
SimTools Plugin for Microsoft Flight Simulator 2020
  1. Icy7CE
    Icy7CE Active Member
    USA
    2,895Coins
    Icy7CE submitted a new resource:
    Microsoft Flight Simulator 2020 Plugin - SimTools Plugin for Microsoft Flight Simulator 2020
    • Winner Winner x 9
    153,565Coins
    +11,144 / 57 / -2
    Thanks so much for all of your efforts :thumbs
    In future updates is it possible to add Game Vibe support?
  3. Icy7CE
    USA
    2,895Coins
    I'm pretty sure GameVibe support would be possible. It's something I'll look into.
    • Winner Winner x 3
  4. Margaritaman
    Margaritaman New Member Gold Contributor
    Sales
    Southern California
    67Coins
    Motion platform
    Thank you very much!
  5. Margaritaman
    Sales
    Southern California
    67Coins
    Motion platform
    Any idea what would cause the motion to cut out intermittently? Simple easy flight with a basic profile, nothing crazy at all. TIA
  6. Aron de Haas
    Aron de Haas New Member Gold Contributor
    - 117Coins
    Nice job! Will tested this later this week
  7. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    thank you
  8. craigN
    craigN New Member
    - 131Coins
    Legend..!! thank you so much.
  9. C0linmac
    C0linmac New Member
    49Coins
    I can't quite figure out how to patch the MS store version of the sim. I can drill down and find the files, but the patch fails. Can I install it manually?
  10. craigN
    craigN New Member
    - 131Coins
    I have the same issue, do to the restrictions with the privilege's in the WindowsApp folder, even after taking folder ownership/Administration.
  11. Icy7CE
    USA
    2,895Coins
    Does the motion ever come back after cutting out? I had a similar problem during testing, which I thought I had figured out, but maybe I need to look at it again...
  12. Icy7CE
    USA
    2,895Coins
    Do you have the file SimConnect.dll? The plugin expects to find this file in the folder selected during patching.
  13. alfsin
    alfsin New Member Gold Contributor
    España
    - 1,019Coins
    first of all thank you very much for your time and contribution with the pluging, but when it is working for a minute suddenly it stops obtaining telemetry data and the tuning center is blocked.
  14. Icy7CE
    USA
    2,895Coins
    Does it ever start receiving data again? Also, do you mean that the tuning center crashes or just stops getting new data?
  15. alfsin
    España
    - 1,019Coins
    I haven't really waited to see if it gets data again, the tuning center program doesn't crash, it just stops receiving data.
  16. alfsin
    España
    - 1,019Coins
    I will do more tests to see if it will receive data again, I will wait instead of restarting the program.
  17. craigN
    craigN New Member
    - 131Coins
    yes SimConnect.dll is in the folder, and this is certainly not an issue with the patch - the issue is with the MS store version (opposed to Steam) is saved to the windowsapps folder, which is restricted, so you cannot access /edit even where the administrator of the folder.. not sure there is any way round this.. i have the same issue for updating my X55 hotas profiles in the same directory.
  18. Icy7CE
    USA
    2,895Coins
    I've done some more testing, and I think I've identified the cause behind the motion data cutting out. I'll post an update soon (hopefully tomorrow) that fixes this.
    As for the problem with the MS Store version of the game, I'll add some files to the plugin zip that allow the patch to be installed manually.
  19. caddyboy0103
    caddyboy0103 New Member Gold Contributor
    11Coins
    I’m having difficulty getting this to work with the ms store version. I installed the SDK, grabbed simconnect.dll and put it in the localcache folder. I open game manager as admin, and I am able to patch the game. The UDP app opens and then after the sim opens to main menu, it states packets sent successfully. When I get to flying there’s no motion, am I missing a step in the process?
  20. caddyboy0103
    11Coins
    Ok, forgot to set min and max for the axis, but it seems like motion is very choppy.
