Question looking for motor to replace three phases
Discussion in 'Motor actuators and drivers' started by cruzebabuze, Mar 29, 2017.
  1. cruzebabuze
    cruzebabuze Active Member
    135Coins
    hi everyone, I have been doing a few motion arcade retrofit, like g-loc. this time around I got an atv track motion arcade to retrofit. what I need is to replace the 3 phases motors it uses. the motor specs are:
    - 150 to 170rpm
    - nm 3
    and I would like motor to be 12v or 24v and not too expensive, not like $300 a piece.
    thank you in advance. here is the link of my thread if you want see pictures of the motors and their full spec.
    size and shaft size do not matter, I will fab shaft extension.
    https://www.xsimulator.net/community/threads/dirt-bike-arcade-retrofit.9926/#post-128582
    thank you all for your help.
  2. eaorobbie
    20,506Coins
    What Nm ya looking for we use 12v 200w DC motors here at 150rpm but would recommend same motor with 50:1 gearbox , under 300 aus
    or currently im looking at ac smart motors 72v AC for a possible 6DOF build , actually cheaper than dc including drivers
  3. cruzebabuze
    135Coins
    Thank you for your help, I need Nm 3 and I already have a gearbox that is around 50:1, but 200w will not cut it, more like 500w or more, and I can not do 72v I am using arduino and some motor boards that go 30v max, already have setup and know it by heart so I am sticking with it. I tried with a winch motor and it was way too slow, I think my winch was around 30rpm, other motors were 150to 170rpm. Thanx in advance
  4. eaorobbie
    20,506Coins
  5. cruzebabuze
    135Coins
    these servo motors are great but a little expensive for me. my track formula open wheel is sucking most of my budget. I was looking more for like 100USD a motor, thank you thought
