Question Is there any way to get a lot of coins?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by 김민혁, Apr 23, 2021.
  1. 김민혁
    김민혁 Member
    - 5Coins
    I want to test the newly constructed 2 axes. However, I haven't been able to get the plugin because I have just joined the forum. Could you please tell me a good way?
    If you have extra coins, could you please donate? Thank you
    152,541Coins
    +11,085 / 56 / -2
    Please be aware that spamming posts for coins is against the Forum Rules and can result in a permanent ban: https://www.xsimulator.net/community/threads/forum-rules.9527/
    When you download SimTools it already has a fully functional plugin installed for Live For Speed, specifically for testing purposes, so use that: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    Make sure that LFS is run before patching it for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
  3. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    You simply can buy what you need - where is the problem?
  4. 김민혁
    김민혁 Member
    - 5Coins
    Sorry. As I was working with a translator, I couldn't understand all the rules. Should I delete this article?
  5. 김민혁
    김민혁 Member
    - 5Coins
    The answer was simple. Thanks for the advice.
