Question iRacing weak pitch
Discussion in 'iRacing' started by leonard, Nov 14, 2017.
  1. leonard
    leonard New Member
    Oil and gaz engineer
    Norway
    232Coins
    3DOF, SCN6
    I was wondering if there are other people experiencing an overal weak iracing movements compared to AC or PC1/2 etc...
    My biggest complain is the pitch. All my other dofs are set to 60 and 40 for traction loss but the pitch i have to go all the way to 150. Dont know if thats safe but at least is starts to communicate weight transfer to me when braking/accelerating.
    I have all my axis set to 80% max for safety. Using SNC6 for a 3 dof setup.
    I will also take the chance to ask about the possibility that mapping more than 3 dof might disturb the main ones. I have a bit of heave for example.
    154,256Coins
    +11,177 / 57 / -2
    For acceleration and braking you should be setting surge, not pitch.
  3. leonard
    leonard New Member
    Norway
    232Coins
    3DOF, SCN6
    I know acceleration and braking are surge motions but thought the result i should be looking for is the pitch angle. I will try surge. Thanks for your quick answer.
  4. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Agree with Norbeast, while you feel a slight nose down in Pitch under deceleration, the movement would be very limited (as you describe) due to the pitch angle only being very minor from the cars suspension compressing on the front end.
  5. leonard
    leonard New Member
    Norway
    232Coins
    3DOF, SCN6
    Yes surge made a difference. I cranked it up to 140 and the result is something I can work with. I think I understand better what surge is to simtools. Since my 3dof is incapable of the surge motion, my idea to put some values there was just arbitrary. I didnt know simtools takes those as inputs and outputs them in pitch. I can assume that, if I want more roll when turning, I should also adjust the sway. Thanks again.
    154,256Coins
    +11,177 / 57 / -2
    Sway leans away from a corner and roll is set opposite to that.
  7. leonard
    leonard New Member
    Norway
    232Coins
    3DOF, SCN6
    What do you mean with roll being sett opposite to that? Isnt that more dependent of the surface angle of the corner. If a corner surface is angled opposite to oval corners, sway and roll should work together. I know this is not the case for most corners but trying to better understand how this is mapped. If a corner surface is lets say neutral, then the g forces applied on the car results in roll which result in leaning away from the corner. To my understanding so far, roll and sway work in the same direction. Now I am confused :)
  8. Brett Horton
    Tampa FL
    118Coins
    In a flat left hand turn, assuming the car stays perfectly flat, there will be zero roll, but right hand sway.
    In a normal banked left hand turn, with no sway (not normal) the car would roll left (into the turn) add sway to this and the Sim will sway right assuming g forces are greater than the affect of the roll. Sway is a G effect....
    In a very slow left hand turn in a normal banked turn, you sitting in your sim would indeed, feel the left hand roll. Speed up in the same turn, sway starts to be prevalent and you will feel the right hand sway and no left roll....
    Ok... I'm babbling at this point
    154,256Coins
    +11,177 / 57 / -2
    SimTools mixes the allocations for each axis/force on the fly, this is how SimTools expects configuration: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  10. bruce stephen
    general contractor
    michigan
    9,115Coins
    roll does not work properly with sway. choose one.
