HELP!! Can someone please share the 10bit Willynovi Code
Discussion in 'Electronic and hardware generally' started by Niranjan, Nov 12, 2020.
  1. Niranjan
    Niranjan New Member
    75Coins
    154,496Coins
    +11,184 / 57 / -2
    That is exceedingly old and there are many other cheap and effective wired and wireless options, check the FAQs here: https://www.xsimulator.net/community/faq/diy-peripherals.13/category
    For example @TOPMO3's work: https://www.xsimulator.net/community/threads/diy-pedals-buttons-controller.8867/page-7#post-182249
    Based on the cheap STM32F103C8T6 ARM STM32 Minimum System Development Board: https://www.aliexpress.com/item/32345958001.html
    Alternatively an Arduino based approach: https://www.xsimulator.net/community/faq/diy-arduino-buttonbox.254/
    Or BlueHID: https://www.xsimulator.net/communit...-for-pedals-buttons-other-types-of-input.266/
  3. Niranjan
    Niranjan New Member
    75Coins
    The reason I want this one is cuz it's the most reliable one I had ever used. And now since able to do some programming, I'll like to upgrade it to a 16 bit version. I need the exact one's code.
    154,496Coins
    +11,184 / 57 / -2
    Happy hunting :cheers
  5. RacingMat
    21,088Coins
    any Teensy has 12bits input (16 bits seems overkill) and reliability is really good
    but I understand if you want to code on the chip you want and like soldering on custom PCB :)
  6. Niranjan
    Niranjan New Member
    75Coins
    Actually mate I'm gonna manufacture the Pedals. That's why the PIC microcontroller solution was best as it's plug and Play. Programming a Teensy isn't everyone's capability so to speak.
  7. willynovi
    willynovi Member
    Argentina
    354Coins
    hi, long time I left away electronic and programming.
    If you want a 16 bit analog to digital conversión, 18f4550 will not be your choice because it´s 10 bits.
    For the source code, sorry man, but I forgot it in an old pc and I couldn´t back up HD.
    I only have firmwares.
