Question game engine is already running message
Discussion in 'SimTools Pro & Entertainment Version' started by Husnu, Oct 18, 2022.
  1. Husnu
    Husnu New Member
    232Coins
    Hi guys
    I get this " game engine is already running " message when I turn on the computer and run game engine. But the game engine is not working. I have to restart the computer to be able to fix this . Sometimes I get the same problem even if I restart computer . I start programs myself. Doesn't open automatically at startup What could be the cause of this problem?
    Regards
    150,686Coins
    +11,018 / 55 / -2
    When you start the computer right click on the Windows bottom bar and select 'Task Manager' and see if SimTools is in the Processes.
  3. Husnu
    Husnu New Member
    232Coins
    There are no processes in task manager.
  4. Husnu
    Husnu New Member
    232Coins
    150,686Coins
    +11,018 / 55 / -2
    @yobuddy do you have any thoughts on this error message?
    150,686Coins
    +11,018 / 55 / -2
    When you start the computer if you open the Windows tray on the right of the bottom Windows bar does it have the icon for Game Engine? If so it may be set to auto start.
  7. yobuddy
    50,333Coins
    I would be willing to bet its your antivirus.
    Since it runs copy of the process in a safe space to check bad stuff on launch, the process launched normally thinks its already running.
    Try adding game engine to your antivirus's white list, and see if it corrects the problem.
    (may have to reboot after adding it to the white list)
    Take care,
  8. Husnu
    Husnu New Member
    232Coins
    Hi yobuddy
    No antivirus program . Simtools does not start automatically. I canceled the autostart as I got the same error. But as you can see it does it when I run it myself.
    Regards
  9. yobuddy
    50,333Coins
    Windows defender?
  10. Husnu
    Husnu New Member
    232Coins
    ok i will try that. Thanks for information.
    Regards
  11. Husnu
    Husnu New Member
    232Coins
    Hi yobuddy
    I added the game engine to defender. But I am getting the same error.
    I have one more question. Game engine crashes when simtools is open.
    For a while everything works fine. But then the action stops and the game engine crashes
    Could it be a problem with my motherboard?
    Regards
  12. yobuddy
    50,333Coins
    Do you mean v2 and v3?
    No, I would think your sim interface maybe.
  13. Husnu
    Husnu New Member
    232Coins
    I use V2 . But if the prosimu interface comes for v3, I can try.
    by the way i spelled it wrong
    Game engine crashes when SIMHUB is open.
    For a while everything works fine. But then the motion stops and the game engine crashes
  14. noorbeast
    150,686Coins
    +11,018 / 55 / -2
    There is a good possibility there is a port conflict, as 2 apps can't use the same com post at the same time.
  15. Husnu
    Husnu New Member
    232Coins
    There is no solution for this problem right ?
  16. noorbeast
    150,686Coins
    +11,018 / 55 / -2
  17. Husnu
    Husnu New Member
    232Coins
    Hi yobuddy
    So do you have any other suggestions for this error?
    Regards
  18. yobuddy
    50,333Coins
    Maybe try rebooting the PC, then give simtools a go without simhub.
    If it works, it's just a port conflict.
    Let me know how it goes.
    Take care,
  19. yobuddy
    50,333Coins
    You could also install AVG free and replace defender.
    I bet it will work.
    Take care,
  20. Husnu
    Husnu New Member
    232Coins
    simhub doesn't work anyway .
    I restart pc when i get this error.Sometimes it crashes again. Sometimes I can run normally
    thank you for your help yobuddy
    Regards
