download plugins?
Discussion in 'SimTools Plugins' started by Jeroen, Sep 30, 2018.
  1. Jeroen
    Jeroen DoctorXeno
    Holland
    - 70Coins
    Hi, I am a pro member. Why can't I download plugins?
  2. yobuddy
    51,743Coins
    154,693Coins
    +11,210 / 57 / -2
    The plugins for Simtools v1 will not work with Simtools v2.
    154,693Coins
    +11,210 / 57 / -2
    You could recreate your previous settings but I think it worth doing them from scratch, and for some hardware, like JRKs, where SimTools 2 offers substantially better movement, it is really necessary to redo motion profiles.
  5. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    I think Tuning Center settings you could copy from your old Simtools, but for motion profiles as @noorbeast said, it would be best to re-create new profiles.
    But if you will use your settings from older Simtools, take notice that with latest Simtools 2.3 - smoothing effect has double the power than before.
    https://www.xsimulator.net/communit...lation-software-simtools.63/update?update=647
    - Smoothing per DOF now carries double the weight
    - Main Profiling % (Smoothing) now carries double the weight
    So before if you used smoothing effect for example at "10", now you need to set it lower at "5" to have the same effect.
  6. Kass55
    Kass55 Member
    PC support
    327Coins
    I use smoothing for surge in particular,
    because I like to smooth out gear change jerk, that you get on some games
