DIY 2DOF simulator - proof of concept model
Discussion in 'DIY Motion Simulator Projects' started by Iain Dodds, Oct 17, 2020.
  1. Iain Dodds
    Iain Dodds New Member
    N/A
    Michigan USA
    78Coins
    I am in the process of build a 2DOF platform at scale to learn about simulator rig configurations, building and software.
    Started off with buying some simple core parts off of amazon.
    Bill of Material.
    • Hobbypark Metal Aluminum Long 25T Servo Horn Single Sided Steering Arm M3 Threads for RC Car Truck Off Road Buggy Accessories (Blue)
    • 2 Sets 20KG RC Digital Servo - Large Torque High Speed Full Metal Gear - Waterproof 180 Degree Servo Motor with 25T Servo Horn for RC Robotic Arm Model DIY Baja Car 1/10 Scale Crawler Truck
    • 10PCS ShareGoo Aluminum M3 Tie Rod End Ball Joint Link Ball Head Holder for Tamiya HSP Traxxas Axial SCX10 1/10 RC Car Truck Buggy Crawler
    • ZXHAO 10mm/0.39" to 10mm/0.39" Inner Dia Rotatable Universal Steering Shaft U Joint Coupler
    • uxcell M3 x 100mm 0.5mm Pitch 304 Stainless Steel Fully Threaded Rods Hardware 10 Pcs
    • Standard Servo Mounting Bracket/Protector (Silver Finish)
    • MakerBeam XL Regular Starter Kit Clear Anodized Including Beams (15x15mm), Brackets, Nuts and Bolts
    Software & Control
    Modified example Arduino code to work with Adafruit 16-Channel 12-bit PWM/Servo Shield - I2C interface.
    Initial Testing
    Video to come soon.....
  2. Iain Dodds
    N/A
    Michigan USA
    78Coins
    • Old Old x 1
  3. ivan jack
    ivan jack Member
    412Coins
    very nice ! Can you share the code please? I'm trying to do the same , but with stepper motors and adafruit v2.3
    152,640Coins
    +11,087 / 56 / -2
  5. ivan jack
    ivan jack Member
    412Coins
  6. Iain Dodds
    N/A
    Michigan USA
    78Coins
    Here's my modified version of the code to make it work with the adafruit pwm hat.
    I commented out the portions from the original example so you can see where and how it was modified.
    Code:
    // RC Model Servo
    // Original code By EAOROBBIE (Robert Lindsay)
    // Completely mangled by aarondc
    // PWM mod by Iain Dodds
    // For free use for Sim Tool Motion Software
    #include <Wire.h>
    #include <Adafruit_PWMServoDriver.h>
    Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
    #define SERVOMIN  80// This is the 'minimum' pulse length count (out of 4096)
    #define SERVOMAX  850 // This is the 'maximum' pulse length count (out of 4096)
    #define USMIN  600 // This is the rounded 'minimum' microsecond length based on the minimum pulse of 150
    #define USMAX  2400 // This is the rounded 'maximum' microsecond length based on the maximum pulse of 600
    #define SERVO_FREQ 50 // Analog servos run at ~50 Hz updates
    uint8_t centerdegrees = 45;
    //#define DEBUG 1                                    // comment out this line to remove debuggin Serial.print lines
    const int kActuatorCount = 2;                       // how many Actuators we are handling
    // the letters ("names") sent from Sim Tools to identify each actuator
    // NB: the order of the letters here determines the order of the remaining constants kPins and kActuatorScale
    const char kActuatorName[kActuatorCount] = { 'R', 'L' };
    //const int kPins[kActuatorCount] = {4, 5};                       // pins to which the Actuators are attached
    const int kActuatorScale[kActuatorCount][2] = { { 0, 90 } ,    // Right Actuator scaling
                                                    { 90, 0 }      // Left side Actuator scaling
    const char kEOL = '~';                              // End of Line - the delimiter for our acutator values
    const int kMaxCharCount = 3;                        // some insurance...
    //Servo actuatorSet[kActuatorCount];                  // our array of Actuators
    int actuatorSet[kActuatorCount] = {4, 5};
    int actuatorPosition[kActuatorCount] = {90, 90};    // current Actuator positions, initialised to 90
    int currentActuator;                                // keep track of the current Actuator being read in from serial port
    int valueCharCount = 0;                             // how many value characters have we read (must be less than kMaxCharCount!!
    // set up some states for our state machine
    // psReadActuator = next character from serial port tells us the Actuator
    // psReadValue = next 3 characters from serial port tells us the value
    enum TPortState { psReadActuator, psReadValue };
    TPortState currentState = psReadActuator;
    void setup()
        // attach the Actuators to the pins
        //for (int i = 0; i < kActuatorCount; i++)
        //    actuatorSet[i].attach(kPins[i]);
        // initialise actuator position
        //    updateActuator(i);
        // put your setup code here, to run once:
        pwm.begin();
        pwm.setOscillatorFrequency(27000000);
        pwm.setPWMFreq(SERVO_FREQ);  // Analog servos run at ~50 Hz updates
        double setpulselen = map(centerdegrees, 0, 180, SERVOMIN, SERVOMAX);
        pwm.setPWM(4, 0, setpulselen);
        pwm.setPWM(5, 0, setpulselen);
        delay(1000);
        Serial.begin(9600); // opens serial port at a baud rate of 9600
        Serial.println("Init Complete");
    void loop()
    void serialEventRun(void) {
      if (Serial.available()) serialEvent();
    // this code only runs when we have serial data available. ie (Serial.available() > 0).
    void serialEvent() {
        char tmpChar;
        int tmpValue;
        while (Serial.available()) {
            // if we're waiting for a Actuator name, grab it here
            if (currentState == psReadActuator) {
                tmpChar = Serial.read();
                // look for our actuator in the array of actuator names we set up
    #ifdef DEBUG
    Serial.print("read in ");
    Serial.println(tmpChar);
    #endif
                for (int i = 0; i < kActuatorCount; i++) {
                    if (tmpChar == kActuatorName[i]) {
    #ifdef DEBUG
    Serial.print("which is actuator ");
    Serial.println(i);
    #endif
                        currentActuator = i;                        // remember which actuator we found
                        currentState = psReadValue;                 // start looking for the Actuator position
                        actuatorPosition[currentActuator] = 0;      // initialise the new position
                        valueCharCount = 0;                         // initialise number of value chars read in
                        break;
            // if we're ready to read in the current Actuator's position data
            if (currentState == psReadValue) {
                while ((valueCharCount < kMaxCharCount) && Serial.available()) {
                    tmpValue = Serial.read();
                    if (tmpValue != kEOL) {
                        tmpValue = tmpValue - 48;
                        if ((tmpValue < 0) || (tmpValue > 9)) tmpValue = 0;
                        actuatorPosition[currentActuator] = actuatorPosition[currentActuator] * 10 + tmpValue;
                        valueCharCount++;
                    else break;
                // if we've read the value delimiter, update the Actuator and start looking for the next Actuator name
                if (tmpValue == kEOL || valueCharCount == kMaxCharCount) {
    #ifdef DEBUG
    Serial.println(actuatorPosition[currentActuator]);
    #endif
                    // scale the new position so the value is between 0 and 179
                    actuatorPosition[currentActuator] = map(actuatorPosition[currentActuator], 0, 255, kActuatorScale[currentActuator][0], kActuatorScale[currentActuator][1]);
    #ifdef DEBUG
    Serial.print("scaled to ");
    #endif
                    updateActuator(currentActuator);
    double pulselen;
    // write the current Actuator position to the passed in Actuator
    void updateActuator(int thisActuator) {
        //Serial.print("actuatorSet[thisActuator]");
        //Serial.println(actuatorSet[thisActuator]);
        //Serial.print("actuatorPosition[thisActuator]");
        //Serial.println(actuatorPosition[thisActuator]);
        pulselen = map(actuatorPosition[thisActuator], 0, 180, SERVOMIN, SERVOMAX);
        pwm.setPWM(actuatorSet[thisActuator], 0, pulselen);
        //actuatorSet[thisActuator].write(actuatorPosition[thisActuator]);
    152,640Coins
    +11,087 / 56 / -2
    Nice one, added to the FAQs here, with credit to yourself: https://www.xsimulator.net/community/faq/build-a-working-model-to-test-your-design-ideas.216/
  8. ivan jack
    ivan jack Member
    412Coins
    Thank you sir!
    Thank you for the time spent on this and for the infos. I'll try it today to see the results. Just woke up to this, such a great morning!
    Thank you for the time spent on this and for the infos. I'll try it today to see the results. Just woke up to this%
  9. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    hi a have problem and trying myself but fail to solve problem i ude this code and one servo i going counterclock and other two r going clock wise . what and where to change that all going clockwise?
