Question dirt rally 2 hardware_settings_config.xml always reset default
Discussion in 'SimTools Plugins' started by stargazer, Jan 4, 2020.
  1. stargazer
    stargazer Active Member
    Electrical/Computer Engineer
    Boston,USA
    811Coins
    3DOF, Arduino, Motion platform, 4DOF
    Hi
    I am having hard time getting dirt rally 2 to work with my motion simulator. I followed the instructions from this thread https://www.xsimulator.net/community/threads/dirt-rally-2-plugin.13081/page-2 to set the udp enabled in the file C:\Documents\My Games\DiRT Rally 2.0\hardwaresettings\hardware_settings_config.xml
    to
    <motion_platform>
    <dbox enabled="true" />
    <udp enabled="true" ip="127.0.0.1" port="4123" ExtraData="3" Delay="1" />
    <udp enabled="true" ip="127.0.0.1" port="10001" ExtraData="3" Delay="1" />
    <udp enabled="true" ip="127.0.0.1" port="22078" ExtraData="3" Delay="1" />
    <fanatec enabled="false" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    but when I ran the game there was no motion. I also found that each time the game was run, the config file would reset to
    <motion_platform>
    <udp enabled="false" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
    <custom_udp enabled="false" filename="packet_data.xml" ip="127.0.0.1" port="20777" delay="1" />
    <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    would someone know how to fix this problem?
    thank you!
  2. yobuddy
    50,295Coins
    SimTools does not auto patch anything.
    Is there anything else installed that could be auto-patching the games?
    Take care,
  3. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,503Coins
    You could try changing the config file to read only after changing it. (Right click the config file, properties and click read only under attributes). Worth a shot?
  4. stargazer
    Boston,USA
    811Coins
    It appears that some other application is preventing the file to be modified. When I changed the file and waited for a few minutes, then the file got changed back to the original again. That is the game didn't even run at all. I wonder if there is a way that can tell me which application was reverting the file??
  5. yobuddy
    50,295Coins
    I seem to remember someone telling me race studio does this?
    I think it was that app anyway...
